Question about LG Shine KE970 Cellular Phone
Ring Tones Help, I have a problem when receiving ring tones via Bluetooth. I Pair up with another device fine and receive the file but then it is no where on my phone. I have a memory card and have plenty of memory on my phone. I have spoken to my network provider but they are going to take upto 3 day's to come back to me. Wondered if anybody knew a quicker solution. Thank You
    Brigadier General:
  • 7,752 Answers
  • try master resetting the phone and see if that helps also try takin' the memory card out of the phone and try the bluetooth transfer again.
Posted on Apr 06, 2008
No ring tones when calling or receiving
make sure your bluetooth is connected properly. enter the passcode if they ask for any while the devices try to pair and make sure you pair the right ones. try to reconnect a few times.
Nov 06, 2015 | Parrot 3200 Ls Color Handsfree Bluetooth...
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Transfering Ring Tones between two samsung rants from sprint
Try using the send tool. Have you paired them? Pair them, and then while selecting the ring tone, you should see something like options or something. Open that, and see if there is a send button, or a send tool. From here somewhere you should be able to select bluetooth. Please rate, and if not, reply so I may further assist you.
Jun 09, 2009 | Samsung Cell Phones
Help using installed ring tones on my nikia 6085
profile ---general---personlize----ringtone(chose the tone from the music folder not received file) -done
May 11, 2009 | Nokia 6085 Cellular Phone
Problem with sending ringtones via bluetooth
First be sure the two phones are visible to each other,Next pull up the file that you wish to transfer, select options (or more), send, via bluetooth. Then your phone should give you a list of targets choose the one that you wish the file to go to and press select. The receiving phone will then as if the transfer should be accepted. Confirm this and the file will transfer....unless the file is too large, an incompatible type or has been "copy protected". Good luck.
May 08, 2009 | Cell Phones
Imate --jama
check the option of "discoverable to other" option in ur blue tooth option then u'll be able receive data and ring tone...copy ur tones to mydevice\windows\rings..then u'll b able to set ringtones...also may b ur mp3 tunes will not work..if not then u have to conver it to .wav or .arm..
Feb 27, 2009 | i-mate JAM Pocket PC
Help me in imate jama problem
hi thanks for using fixya!!
Please check the Bluetooth Settings, then select Mode, you should tick the "Make this device visible to other devices".
Then, select BEAM, then tick "Receive all incoming beams" to enable you to receive datas via bluetooth.
Then, make sure you have enough spaces to your internal memory and external SD card.
Hope this will help, let me know if you need further assistance.
Don't forget to rate me with my simple solution. Thanks!
Feb 26, 2009 | i-mate JAQ3 Smartphone
Ring tone
This information is from the Motorola Customer Help web pages.
To connect your phone via USB to computer and access your phone's memory card:
On your phone:
  1. Press the Center Select Key
  2. Scroll to and Select Settings
  3. Scroll to and Select Connection
  4. Scroll to and Select USB Settings
  5. Scroll to and Select Default Connection
  6. Scroll to and Select Memory Card
    This directs the USB connection to your memory card. Attach the Motorola Original USB cable to the accessory port on your phone and to an available USB port on your computer.
question.gif How do I use my own ring tones on my phone?
space.gif space.gif answer.gif To put ring tones on your phone using Motorola Phone Tools 4.36c and higher:
  1. Start Motorola Phone Tools.
  2. Choose your phone's profile or create a new profile.
  3. Click OK to wait for a picture of your phone to appear or for your phone to be setup for the first time.
  4. Once the image of your phone appears in the lower right of your computer screen select Multimedia Studio.
  5. On the screen that pops up select Melody Studio.
  6. Select a tab at the top of the screen to find a source for a ring tone. (Samples, My Melodies, My PC, My CD, My Phone).
  7. Select an audio phone you wish to transfer or edit.
  8. Edit the file to your taste or simply choose Transfer to phone.
  9. The file will be put in your ringtone folder.
To transfer music to your phone via Bluetooth(The computer must have a Bluetooth Profile that supports OBEX File Transfer ):
Note: The steps you may need to use to transfer music via Bluetooth may differ from the steps used below. A PC and a Motorola PC850 Bluetooth Adapter were used in the steps seen below.
  1. On your computer
    1. Go to My Bluetooth Places
    2. On your phone
      1. Push Menu
      2. Scroll to and Select Bluetooth
      3. Scroll to and Select Setup
      4. Turn Bluetooth Power On
      5. Push Back (right softkey)
      6. Scroll to and Select Find Me
      7. Press Back several times to return to the home screen
    3. Double click Find Bluetooth Devices
    4. Let your computer search and find your device
    5. Double Click on Motorola Phone (Phone's default name is "Motorola Phone" unless you have renamed it in Bluetooth>Setup>Name
    6. Double Click on OBEX File Transfer on Motorola Phone
    7. Computer will be prompted to enter a Passkey
    8. Enter 0000 on your computer and press OK
    9. Phone will ask if you want to Bond with your computer. Select Yes or No
    10. Phone will then prompt you to enter the 0000 Passkey then press OK
    11. Phone will then prompt to Grant or Deny OBEX File Transfer
    12. Double click on audio Folder
    13. Phone will then prompt to Grant or Deny OBEX File Transfer
    14. Computer will now display a conversations and voicerecords folder. Copy and paste or Drag and Drop your m4a (AAC) or MP3 ring tones to the audio folder and NOT into the conversations or voicerecords Folders.
    15. Phone will then prompt to Grant or Deny OBEX File Transfer to complete the transfer
Note: By putting ring tones on your phone using Bluetooth or Motorola phone tools, you may not be able to remove the ringtone from your phone. Motorola is aware of this and in the future removing the user added ringtones
Regards,
Worldvet
Jun 10, 2008 | Motorola Mobility RAZR V3
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
Troubleshooting RIM BlackBerry 7290 bluetooth will not hook up with my other phone or my wifes any help to get them connected so i can transfer my ring tones
Many ring tones are "locked" by copywrite by the carrier. Also, transferring from device to device may only work if the same version of bluetooth is on both devices.
I have connected cells to blackberries before... usually hit or miss.... most likely, you will have to first transfer the file to your computer, then to the other device.
Sorry I can't be more helpful. :)
Jan 29, 2008 | RIM BlackBerry 7290
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
