Question about Garden
Stepper motor control accrding to counter input by MCU 89c8051
Dear I have two feeding pipes in a tank.One pipe feeds water and other pipe feeds chemical, now I want to control the damper of the chemical feeding pipe by means of stepper motor controlled by a microcontroller 89c8051 according to the flow of water which is flowing from the water feeding pipe, a counter meter is installed on the water feeding pipe.
I need the microcontroller program to conrol the chemical feeding damper by a stepper motor 0~90 degree.
You can suggest any type of stepper motor, I need the microcontroller program which counts the water feeding counter pulses and according to the counts, control the damper of chemical feeding by means of stepper motor (+) and (-).
I shall be very thankful to you.
Kind regards,
Asif.
protek480
  • 1723 Answers
SOURCE: the shower just give off piping hot water
Is it hooked up to a hot water line? Change it to a cold line.
Posted on Jul 05, 2009
  • 990 Answers
SOURCE: decreased flow visable.
No they just stop, if your loosing flow it is from a block usually in the suction or quite often in the front of the pump the impeller will fill with stuff. A probe like a screwdriver and a set of needlenose pliers will fix this if you go in through the front of the pump.
Posted on Oct 04, 2009
james3751
  • 614 Answers
SOURCE: hydronic heat water feed valve
You should be ok. Most of the time the boiler are charged to about 10psi and dont have feed valve. You would only feed if you have a slight leak in system. Rus
Posted on Dec 05, 2009
  • 990 Answers
SOURCE: water flow problem
You probally have some ice still in the feed line to the house. You may have to pull the pump and thaw the line. It should be in the very top of the line. You may be able to force hot air down the caseing. Or ifit is bad you might have to dig up the line from the well to the house and re wrap with heat tape. Good luck.
Posted on Feb 05, 2010
SOURCE: The water flow to the humidifier is only being
Needs new float assembly.
Posted on Mar 15, 2010
How do I install my hot water heater?
Youtube offers many videos of the water heater installation. Drain first with a garden hose. after turning off water and unplugging electric or shut off gas.
If changing to a tankless, remember they often require a larger vent pipe to the roof. 4" usually, not the 3" for tank water heaters. Local building codes may require a permit and a larger Gas feed pipe.
Also if you're going to use the old Pressure Relief Valve DO NOT test the valve by activating the little lever. Once used over time their internal seals weld onto the closed seat and tend to rip and leak if you test the valves function. Replace with new ( $15) if it's been operated. Most plumbers now use Braded Feed Lines from/to the Water sources, making future replacements easier. You might find the replacement Tank is not the same geometry as the old one, having longer braided feed lines helps when they are on opposite ends of the tank top and the original feed lines are copper and wont reach the new tank pipes or the tank gas starter door is on the back side requiring you to rotate the tank 180. If you're changing size, measure the width and height. It might not fit the old installation.
Apr 24, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Fitting evo oil tankwith different pipes
There are 3 connections on the new tank. 1- feed/suction. 2- return. 3-breather. You should be able to look inside the tank and tell which is which. The 2 coming in the front botton is feed and return. The return should have a small tube sticking up inside the tank. The feed will not have a tube on it. The breather will be at the top of tank (if it is on the bottom it will also have a tube sticking up inside the tank.
Nov 30, 2013 | Motorcycles
Which tank pipe is the feed on a 20001200 evo sportster
is there one large pipe and there a small bore pipe? large pipe will be feed and small be a pulse pressure pipe ! P....
Nov 29, 2013 | 2006 Harley Davidson XL 1200 C Sportster...
How to drain71- 40 .where is drain need to replace hearer need to drain first. 50 gal
There is usually a spigot right at the base of the water heater. Thread a garden hose on the spigot and route the garden hose outside. Of course be sure to pull the power breaker first. After you are sure that the power is off, turn the spigot handle and let the water flow. Be sure that you turn the inlet valve off that is located on the top feed pipe. Be sure to turn the feed back on before you power up as this will ensure that the upper and lower calrods are covered before you power on.
Jan 22, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Where is the thermostat on a 2002 Chev. Cavalier with a 2.2 DOHC located?
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. Specific instructions from autozone.com for your car are pasted below. If you get stuck, please get back to me.
  1. If equipped with an automatic transmission, remove the exhaust manifold.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
Remove the thermostat housing to water pump feed pipe.
Fig. Remove the thermostat
  • Remove the thermostat.
  • To install:
    1. Install the thermostat.
    Install the thermostat housing to water pump feed pipe.
    Fig. Install the thermostat housing to water pump feed pipe
    1. Install the thermostat housing to water pump feed pipe bolt and tighten the thermostat housing to water pump feed pipe bolt to 89 lb inches (10 Nm).
    2. If equipped with an automatic transmission, install the exhaust manifold.
    3. Fill the cooling system.
    Nov 23, 2010 | 2002 Chevrolet Cavalier Coupe
    How to install thermostat
    from autozone.com
    2.2L Engine
    1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
    4. Remove the thermostat housing to water pump feed pipe.
    1. Fig. Thermostat mounting-2.2L engine
    2. Remove the thermostat.
    To install:
    2. Install the thermostat housing to water pump feed pipe.
    3. Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 89 inch lbs. (10 Nm).
    4. If equipped with an automatic transaxle, install the exhaust manifold, as outlined in this section.
    5. Fill the cooling system.
    3.1L Engines
    1. Disconnect the negative battery cable.
    2. Drain the cooling system to a level below the thermostat housing.
    3. Remove the air cleaner assembly.
    4. Disconnect the surge tank line from the thermostat housing.
    5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
    6. Remove the thermostat.
    To install:
    1. Clean all gasket surfaces completely.
    2. Insert the thermostat in the intake manifold.
    3. Attach the thermostat housing to the intake manifold.
    4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm).
    5. Install the air cleaner assembly.
    6. Connect the surge tank line to thermostat housing.
    7. Refill the cooling system.
    8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
    9. Install the radiator cap, making sure the arrows line up with the overflow tube.
    Sep 25, 2010 | 2003 Pontiac Grand Am
    How to change the thermostat
    Alero, Grand Am 1999-2005 Thermostat - Removal & Installation 2.2L Engine
    5. Remove the thermostat.
    To install:
    3.1L Engines
    To install:
    3.4L Engine
    1. Drain the cooling system.
    2. Remove the air cleaner.
    3. Remove exhaust crossover pipe.
    4. Disconnect the surge tank line fitting from the coolant outlet.
    5. Remove the thermostat housing to intake manifold bolts.
    6. Remove the thermostat housing outlet and thermostat
    7. Clean the mating surfaces.
    To install:
    1. Install the thermostat and housing outlet.
    2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
    3. Install exhaust crossover pipe.
    4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
    5. Install the air cleaner.
    6. Fill the cooling system.
    7. Inspect the system for leaks.
    Hope this help (remember comment and rated this).
    Apr 04, 2010 | 1999 Oldsmobile Alero
    Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
    The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
    Jan 18, 2010 | Dishwashers
    No heat in the car
    CHECK THE HIGHT OF THE HEATER MATRIX IN THE CAB , IF ITS HIGHER THAN THE FILLER/EXPANSION TANK. THEN ITS AN AIR LOCK, LOOK FOR THE HIGHEST PIPE AND SEE IF THERE IS A BLEED VALVE, IF NOT TAKE BOTH PIPES OFF THE MATRIX FEEDS AND FLUSH OUT TO SEE IF IT IS BLOCKED, AND RECONNECT LOWEST PIPE FIRST AND FILL SYSTYM TILL WATER APPEAR FROM TOP AND RECONNECT RUN MOTOR, AND KEEP TOPIN UP
    Dec 05, 2009 | 2000 Saturn SL
    Garden Logo
    46 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
