Just bought a house with a big old gas wall heater in what i think was originally a fireplace. Only half of the heater turns orange when it warms up. The flames along the bottom are all on and blue, it seems the panels in the back arent doing what tey are meant to??? Would appreciate any ideas.
    Sergeant:
  • 235 Answers
You'll need to remove the faceplate of the heater. Make sure it's off when you do this. Look inside the unit before you power it back up. You should be able to see your gas valve and the pipe that feeds the burner. Your going to find a simple air/gas controller. Depending on your heater, it could be a simple sleve that your able to turn to adjust your air/gas misture. Orange means you have to much air. You'll need to adjust it slightly to make sure you have a good mixture. You'll want a nice clean blue flame on all of the burners. Because it's a simple heater, you might or might not get all blue flames. If you can't, make sure they are blue as much as you can with the least ammount of orange possible.
Posted on May 11, 2010
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
We purchased a home with an electric start/gas fireplace...no owners manual...we turned on the gas with the key, flipped the switches on the wall and the fireplace unit...we see the ignitor clicking and a...
Not for sure what you have, but if you just purchased the house, there might be air in the gas lines. If it sat vacant and the gas was off, or if they has swapped meters/worked on gas lines? Try cycling the fireplace several times. Or look around for a small door opening or if it's mounted to the exterior wall, look outside for the supply line in. If you do find a valve in the closed position, be aware of the fact that it may be off due to a reason, and you may want a plumber/fire place tech to service it.
Oct 19, 2017 | Leisure HOMEPRIDE Electric Fireplace...
I have a Marco Natural Gas Direct Vent Fireplace that you turn on with a wall switch. Lately it will not light when the switch is turned on, this happens about 50% of the time. It is not the switch because...
The only thing a fireplace like your has that could be faulty is the thermocouple or safety switch on the gas valve.
A thermocouple is a likely suspect. Look in your manual for a part number and buy a replacement. Cleaning the old one might work too if it is heavily coated with carbon.
Dec 16, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
I recently bought a house w/ a Marco gas fireplace and there is no owners manual. I have never used a gas fireplace, so I have no experience with this. I would really like to get an owners manual, but...
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
Nov 08, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Nov 03, 2008 | Heating & Cooling
Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
