Swintec 640 tw
The ribbon is not advancing fast enough so overlapping of char. on ribbon , is there a multi-strike mode ?
  • Anonymous Mar 28, 2008
    Yes found the solution .
    code and the ? enters multi-strike mode
    code and the . exit the multi- mode
Yes did find fix it was in multi-strike mode
the code key and the period pressed down exits M/S mode
the code key and the ? key enters M/S mode
Posted on Apr 03, 2008
  • 3,594 Answers
Try code comma or peroid I know this is what they used in the later models.
DickyO
Posted on Apr 01, 2008
SOURCE:
Swintec 2500 printhead won't strike the cartridge ribbon.
there is a rubber seperator that is bad this will not let it hit hard enough to strike the print wheel. your local typewriter shop should take care of it.
Feb 01, 2017 | Swintec Office Equipment & Supplies
Ribbon is not feeding enough
Under ribbon left side small screw , loosen and you can slide an small arm forward or back to give you more ribbon feed, may work. don't take screw out just loosen and slide.
Sep 19, 2013 | Swintec Office Equipment & Supplies
Swintec 2600. Ribbon is not advancing properly. Types in same place randomly.
You may be in the overstrike ribbon mode. Try code and . , or / one will get you out of the mode.
DickyO
Jun 25, 2012 | Swintec 2600 Electric Typewriter - Tested...
For a Swintec 8014 typewriter: the bottom portion of the letters are not tranferring to the paper when the keys are striked. although the ribbon shows the full letter being striked, only the top portion...
Check to be sure the ribbon dosen't have a fold in it and is fully seated in place, be sure the platen is fully seated in the side frames, check the correction tape for proper imstallation it can rob the print if to high.
DickyO
Dec 03, 2010 | Swintec Office Equipment & Supplies
NAKAJIMA AE-800
hitting "code + /" puts ribbon drive mode into multi-strike ribbon mode, to correct this hit "code + ."
Oct 23, 2008 | Nakajima AE-740 Typewriter
Problem with illegible type
I called the 800-809-7138 number and the tech told me to press the code button and the period key and it removed the multi strike (?) mode. Thanks for checking back!
Oct 14, 2008 | Nakajima AE-830 Typewriter
Olympia typewriter multi strike ribbon mode
Try code . or , one of them should change the ribbon spacing mode.
DickyO
Feb 26, 2008 | Olympia Startype 3 Typewriter
Swintec 7040 typewriter ribbon feed.
The typewriter is supposed to automatically adjust itself to the type of ribbon you have installed. Have you tried a different ribbon?
Feb 11, 2008 | Swintec 7040 Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
130 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
