Question about Digital Media AL Tech MEDIAGATE MG-450HD Player
Mediagate 450hd unreponsive blue flashing light
When i turn on the Mediagate it flashes blue (not connected to PC) and doesn't respond to anything, not even the power button. When connected to the tv nothing comes up, however I can still access everything when connected to my PC.
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
VX2835wm. When plugging in to wall, screen flashes for about 2 minutes; there is no yellow no blue LED. It will not respond to on off button until it has finished the flashing routine.\r\nThen blue LED...
Hi, According to your problem, Check the adjust switches and readjust the monitor first. You have to repair the PCB of the monitor. Better if you can replace the PCB of the monitor.
Sep 02, 2011 | ViewSonic VX2835wm Monitor
Unable to watch movies
Assuming you have the latest firmware update installed (late 2008 I think) Mediagate 450HD won't play MP4 or H264 encoded files. It also won't play MKV or MWV files - there may be others but these are the file types I have encountered the same error when playing. Some MP3 music files won't play either but I have yet to investigate why this is. Solution - convert the file to standard AVI format - keep the same settings as the original file. There are a number of Windows (AVI Convertor) and Mac based programs that do this - Google is your friend. Hope this helps
Oct 08, 2009 | Digital Media AL Tech MEDIAGATE MG-450HD ...
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
Epson FX-890 All lights flashing
when switch printer on after replacing cartrige all the light on printer are flashing how can I reset it
Jun 27, 2008 | Epson FX 890 Matrix Printer
Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Al Tech Mediagate MG350D
Keep hitting the TV video button, it's probably just booted in the wrong video mode.
Might need to hit it a dozen or so times until it comes back on the screen
Aug 22, 2007 | Generic Memory AL TECH MG35 MEDIAGATE...
Digital Media AL Tech MEDIAGATE MG-450HD  Player Logo
153 people viewed this question
Top Digital Media Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Media Audio Player and Recorder Expert? Answer questions, earn points and help others
