Question about Nintendo DS Lite Console
Action replay ds
When i turned ds with the action replay ds inserted it just turned white and it does not happen anything it is just white
please helllllllpppppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • 2 more comments
  • donbran Mar 28, 2008
    when i insert another game its still white
  • Anonymous Mar 28, 2008
    My action replay ds wont work. I turn the ds on with the action replay in it and the screen goes white.
  • Anonymous Apr 01, 2008
    i have the same thing but a little different when i turn it on it goes fine but when i press start it goes completely white
  • Anonymous May 13, 2008
    mine is the same, do i have to get a new one ?
Buy a new one
Posted on Jun 21, 2008
Babys
Posted on Apr 01, 2008
    Problem Solver:
  • 11 Answers
Wath this video http://www.fixya.com/support/t636896-ar_broken
Posted on Jun 23, 2008
SOURCE:
When I turn on my DS lite with the action replay ds inserted, the ds screen comes up, then it turns white and freezes. I have tried to restart it, but that doesn't work.
Ikr it happened to me cause I accidentally clicked delte all codes twice I tried everything I mean everything I'm getting a new one u should to.
Jul 05, 2011 | Datel Action Replay for Nintendo DS
Whenever i start up my DS with my action replay inside, it will instantly go to white screen of death. is there any way to fix this?
i believe not. you may have permanently caused damage to either your action replay or DS. if this only happens while your action replay is inserted, it is likely a problem with the firmware or hardware, your action replay device may have loose wires or circuitry, or have a scratch(es) on the outer metal strips used for the DS to read the device.
May 10, 2011 | Video Game Consoles & Games
When i load Pokemon White in the action replay when i press start game the action replay freezes
Update your Nintendo DS action Replay to this version 1.71 and it will work the website you can get this at is http://uk.codejunkies.com/search/codes_search.aspx and on the right hand side you will find Help Pokemon Black And White, there you should find Action Replay DS Version 1.71 Firmware Update download it as an winrar then extract it to your desktop and drag the file over the bar with your action replay inserted in the code manager. When it has finished writing the firmware it will disconnect you from your computer and messege will come up saying 'Reboot your NDS now! you do that by switiching it off then when you switched it on it should say version 1.71, Insert Pokemon white after taking out the action replay then press start game when it comes up Nintendo That means it is working and there you have it you can play Pokemon White with codes and it doesn't freeze at all, So Enjoy.
Mar 18, 2011 | Datel Action Replay for Nintendo DS
My Action Replay is crashing.
if its one of the micro sd card action replay you can try to format it.make sure you get all of the data off for this take it back to the first time you got it from the store.
Aug 10, 2009 | Nintendo DS Lite Console
I cant press next after i put in a code
Please make sure that you are entering the Game ID correctly. Follow these steps to find the Game ID before beginning the code entry process: •Turn on the Nintendo DS with the Action Replay inserted •At the Main Menu when you are instructed to “Insert Game Cart”, remove the Action Replay and insert the game. •On the top screen of the DS, the name of the game (or Unknown Game) will appear. •The number under the Game Name is the Game ID. Please be sure to include the dash when entering the Game ID into the Action Replay.
If this did not solve your problem, please leave a comment and I will get back to it as soon as I can.
Jul 28, 2009 | Datel Action Replay for Nintendo DS
When i turn my ds on with AR in it, the screen turns all white
may be your action replay is broken. try another action replay with another ds. also try your action replay with another DS.
Jul 23, 2009 | Nintendo DS Lite Console
ACTION REPLAY DS MEGA PROBLEM
I had the same problem, the solution is kinda simple (at least for me). The DS Action Replay after a while will not seat correctly, just pull the DS AR out => press the AR back in the DS firmly, then place the DS Cart into the slot. this should help. Also you may try plugging in the usb cord and then turning on the DS. It may be an Update problem.
Jun 22, 2009 | Datel Action Replay for Nintendo DS
Action Replay DS has deleted avery single cheat code it came with
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
source codejunkies
May 13, 2009 | Datel Action Replay for Nintendo DS
Help
Don't return it! Your Action Replay DS is corrupted. To fix it, turn the DS on (with AR in it) while holding A and B. Then, at the white screen, after "Nintendo DS" but before "This product is not licensed or endorsed by Nintendo", hold down Start and Select while still holding A and B. A few seconds will pass and then the title screen will appear. A few seconds after it appears, release all the buttons. The screen will go white, so just restart the device. Now do a Quick Update in Action Replay Code Manager (on the PC) by pressing the Quick Update button in the corner of the window while the AR (still inserted in the DS) is connected via USB. After it's done, viola! A fixed Action Replay.
Apr 15, 2009 | Nintendo DS Console
Action replay
sorry to disappoint you but there is no way of fixing it, you should get a free replacement depending on how long you have had the card, ive had my action replay for over a year now and it works perfectly, the card you have is corrupted trust me try and get a replacement from your manufacturer.
Jul 21, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
142 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
