Question about Razer Copperhead RZ01-050100-R1M1 Mouse
Razer Copperhead mouse problem
Hi
Just bought new mouse - razor copperhead. The problem is - after plugin up the device my PC wont start. It's stopping on a BIOS screen and wont go further. I've checked the mouse on another PC and it is working, also i've checked all my usb ports - the same thing, it just wont start.
Can you help me to solve that problem??
Best regards
  • Kuba81 Apr 03, 2008
    Thanks Krenn, I've checked BIOS setting, it's not set to boot from USB. I think that it could be a problem with unsufficient energy...
    I think I will just give back the Razer mouse and take something diffrent.
    Regards
Its a common problem on certain motherboards with several USB devices (not limited to the mouse, also been known to happen with Ipods and such) if you remove your mouse (or at times you might need to remove "all" USB devices) the computer should start-up with no problems. When the windows log-in screen is reached you can plug them back in.
A solution to this is updating (flashing) the bios. (you might want to have an expert do this for you)
Or if it doesnt bother you to much,.. simply remove your usb device(s) on startup
Posted on Jul 16, 2013
  • 59 Answers
Check the BIOS settings on your computer: is it set to boot from USB drive?  that may be the problem.
Posted on Mar 29, 2008
Copperhead cursor won't move when i move the mouse
this is because the laser light in the mouse had gone bad...all that you can do is to replace that with a new one... or buy a new mouse...
Apr 04, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My Razor Copperhead mouse restarts
I found that when this was happening to me the problem area was where the wire meets the mouse. By wiggling that (moving the mouse) it would cause it to disconnect and reconnect.
Some claim it could be the firmware for various hardware pieces on your pc IE: motherboard, usb. Depending on how old the mouse is this could be true. Mine, however, is 4 years old and needs to either be repaired or replaced.
Mar 30, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My scroll isnt working on my razer copperhead, any ideas?
Just had the same problem with my copperhead... firstly go to url below to show you how to open up the copperhead (only do this if it's out of warranty!! which is two years if you have your purchase recipt) http://razerblueprints.net/index.php/Copperhead/copperhead-disassembly-guide.html . Once you have got the top off look at the front where the wheel attaches you can pull the wheel out of the circular thing on the left then find some thin paper I used some laser receipt paper (probably gonna wear out but will find something better in meantime) cover the hole with a very small square of whatever thin material you have chosen then push the axle of the wheel back in... this tightens the hole back up allowing the clicking feel to come back and the scroll wheel to work again.
Ultimately the problem is wear and tear with the hole for the axle or the shape of the axle end wearing down.
Jan 01, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My copperhead Razer mouse has started double clicking for one
This double-clicking can be due to a worn out micro-switch in your mouse. If you are well -verse with repairing such gadgets, you can go ahead and replace this switch yourself or refer it to a qualified technician
Apr 23, 2009 | Razer Copperhead Chaos Green Gaming Mouse...
Copperhead working, but not detected
what i did was. i went into c drive -> program files -> Razor -> Copperhead -> driver64 and ran the program called "DPInst"
try that and see if it works
Dec 09, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer
Hmm...I managed to solve the problem of mouse "breaking" while playing counter strike..Its a lil technical...
1. Right Click My Computer -> Properties
2. Choose 'Hardware' tab and then 'Device Manager'
3. You should see a Yellow exclamation mark on 'Razer Copperhead USB mouse' under 'Human Interface devices'
4. Right click -> properties
I do not exactly remember the wordings of the prompts that appear after this..
5. Click on something which says "install / update driver"
6. Choose the 1st option which has something missing in one of the columns..
7. Unzip downloaded driver files on your desktop
8. Choose logical options from here...
9. At some point it will ask for "Razerlow.sys" file...
10. Click browse and go to C:\Windows\system32\drivers....you will find it there...
11. Choose logical options from here and your "breaking" problem will be solved...
This does not solve the "No mouse detected" message in configurator...but atleast you can play your favorite game :-)
May 17, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Feb 18, 2008 | Razer RZ01050300 Mouse
Detected before, but not after. Help me please,
Go to device manager and uninstall everything under the USB heading and restart your computer. This should reinstall all the drivers and hopefully reinstall your mouse. You may need to rerun the driver you downloaded for the mouse afterwards.
My next suggestion your be to try the mouse on another computer to make sure it is not defective.
Jan 15, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Scroll (mouse 3) doesnt click
you got to change options on options of the razer ;) is on the options scrool I hope helps sorry but I am portuguese
Dec 02, 2007 | Razer Copperhead RZ01-050100-R1M1 Mouse
Mouse cutting out
Wish i had a proper solution for this, but im getting the same problem but have found out something interesting....
I recently formatted my machine (xp) and i didn't have a single problem for about 4 weeks!
I have an idea that its a windows update that causes the problem.
Oct 17, 2007 | Razer Copperhead RZ01-050100-R1M1 Mouse
Open Questions:
Razer Copperhead RZ01-050100-R1M1 Mouse Logo
341 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
