Question about Panasonic Lumix DMC-TZ15 Digital Camera
Hello there, i have had my tz15 for 18 months and have never had a problem it until now. I taking video at the time and then I went to zoom in and the lens started to do so maybe 1x, hesitated then retracted back into the camera as if it had been turned off and a message displayed on the white screen "Please turn camera of then on again". This doesn't work, i can still take photos but when i try to zoom the same thing happens every time. I was taking some shots and video of some electric arc welding from quite close range (not close enough for any heat damage) round the same time? any ideas?
I had the same problem. Tried on and off and press every button and it still tells me to "Please turn camera of then on again". I took my SD card out, turn it on in display mode, select menu, go to internal memory, erase all files in the internal memory. it works. I got my camera back and working. Hope this helps.
Posted on Aug 22, 2010
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 11, 2010
The zoom wheel does not stop when I want it to. It like it has its "own" will... Once I start zooming it goes all the way until the max. Sometimes when I make it (somehow... I don't know how)...
Hello.
It sounds like your camera's lens is broken. Did you accidentally drop it? When you shake your camera, do you hear something moving inside? Like a loose part? Or looking in the lens do see anything amiss?
Aug 13, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a Zoom sb-246 beat kit and i had it for a while...but havent used it in months so i turn it on and when it does its stuck on the coming on screen and stops at the screen sayin sb-246 and thats...
Greetings, I too have experienced the exact same problem & for over two years, hadn't found and answer or solution until this month August 2024.
Be of good cheer, to answer your question is quite simple.
While your ZOOM SB 246 is off: press the record button.
While holding the record button down, turn on the power .
In your display, you will see the word: ALLINIT flashing.
Press your record button a second time & the word COMPLETE will be in your display .
Thus indicating that you ZOOM SB 246 has been restored to its factory settings.
My SB 246 did the same thing but I refused to get rid or pay a repairman to take a look at my drum machine.
It paid off.
Give thanks & praise.
Pass it on.
Aug 11, 2011 | Audio Players & Recorders
Camera Zoom Feature
Awesome ! ! ! That works ! ! ! ... Turning off, removing battery for 30 secs., putting it back on, and reboot. Thanks ! ! !
Jul 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
Need to set the date and can't find manual--
Try this:
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
After 20 months old and now dead
I purchased this tv 2/06 and it went POP in 04/07. Less than 60 days after my warranty expired. Went back and forth with Zenith for several months. I refused to take NO for an answer. Customer service stinks and you have to be very persistent. They eventually agreed to fix it. Repairs cost over $2000 and I have my tv back. Next time it breaks just going to throw it out. Zenith sucks.
May 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Panasonic Lumix DMC-TZ15 Digital Camera Logo
187 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
