Question about Maytag Washing Machines
How do you clean the rim around maytag washing machines
  • Maytag Master
  • 1,214 Answers
Always dry the inside of the rim with a dry cloth after each use
Posted on May 15, 2010
How to install the shipping bolt for maytag lat2500 washer?
Hello Phyllis,
The way Maytag did that was by a plastic ring that fit in the lid rim it was deep enough that it would fit inside the top rim of the outer tub cover locking the tub into place. If in your area their is a small independent shop that sells and services Maytag appliances they may have a extra one lying around in the back,if not a peice of styrofoam shaped to fit under the lid and into the tub it would lock the tub into place for shipment.
Gene
Aug 01, 2011 | Maytag LAT2600A Top Load Washer
Maytag Performa does not rinse well even on second rinse. Blotches on clothes. Have cut way back on detergent. Still does it.
I had the same problem. It was a buildup of gunk (don't know how else to describe it) in the fabric softner dispenser. I also had a build up of detergent around the upper rim of the basket inside the washer and caught up underneath the agitator. I took my machine apart and scrubbed it all out.
Here is the way to get it cleaned out.
  • Remove the fabric softener dispenser from the top of the agitator.
  • With a 7/16 socket, remove the bolt inside the agitator.
  • Lift the agitator up and out of the basket. This may require a little force.
I use a small putty knife to scrap the buildup then use a rag to wipe the film off. Make sure to clean the fabric dispenser really well. There are small holes in the bottom of it and if they are clogged up, the fabric softener cannot disperse well and when the machine goes into the spin cycle, it will tend to fling the softener under the rim of the basket where it will buildup over time and leave spots on your clothes.
If you need to know anything further, please don't hesitate to let me know.
richroth_62.gif Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag Performa PAV2200
We have well water w/sediment filter. soap in dishwasher and washing machine does not dissolve. washing machine has heavy build-up around rim after only a few wahings.
get water tested,sounds hard,filter doesn't solve,test before invest, get 2-3 reputable solutions,they will be salesmen,u may simply need softner or could be more difficulty such as iron,etc
Aug 02, 2009 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Rim around machine is mouldy. How do I clean or replace it?
run your washer thru a wash cycle with a cup of vinegar instead of soap. Do not put clothes in with it.
May 20, 2009 | LG WM2688H Front Load Washer
Buildup/smell inside washer
  • Hi,
  • Try this..
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Please rate my suggestion...
Apr 14, 2009 | Maytag Washing Machines
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
