Question about Nintendo Wii Console
HELP PLEASE!!!!!!! Please help me. My wii console can turn on but my two wii remotes won't connect to my wii. I've had my wii for almost two years and this has never happened. I tried syncing it and i tried to charge it but it won't connect. The blue light on the wii remote blinks but it wont connect. Please help me.
  • danny1997 Mar 28, 2008
    This happened when i was about to play guitar hero 3.
  • Anonymous Mar 26, 2014
    One day I went to play my Wii and I saw that the light just went black as if I unplugged it. Its been like that for almost half a year. My dad unplugged all the cables and quit on trying to fix it. Please help!
    Sergeant:
    Champion:
  • 250 Answers
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Posted on Mar 29, 2008
Just go to walmart get a new wii and switch it then take it back they will just ask if there somthing worng just say it dont work wont turn on they will just give you a refund just dont lose the recept
Posted on Mar 28, 2008
SOURCE:
My Wii won't turn on! :(
some one is turning it off or becuse you were sitting on a wii remote.
Apr 07, 2013 | Nintendo Wii Console
My wii console will not allow my remotes to work i cant get pass the 1st screen i,ve tried three different remotes please help
what you need to do is replace batteries in a controller and if it still doesn't work then you need to sync the controller to the wii.
Jul 07, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
My wii works fine but the remote wont connect up to the wii.batteries are brand new but when you turn on the remote the blue lights flash then go of i,ve tried 3 different remotes with the same outcome.
Hi there
From what you have said it sounds like you have the Sync error
The main cause is Hardware failure due to overheating or just simple wear & tear.
You will need to perform simple maintenance to your console
You can send your Wii to Nintendo to fix this. If your in warranty its free. If not the repair cost would be $150 and a wait time of 4-6 weeks
The other solution is what I did and the way more and more gamers are turning nowadays is a Good Wii Repair Guide that shows you how to fix the problem yourself. I have never had a problem with this one so far for over a year, well worth it. Its my most recommended guide online.
Well this is all the help and advice I have on this so good luck.
You can get back to gaming
Please come back and rate my post if you find it useful
Many thanks
Chris Foley
Feb 08, 2011 | Nintendo Wii Console
THE WII REMOTE FLASHES BUT WON"T CONNECT TO TURN
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Dec 09, 2010 | Nintendo Wii Console
My wii remote ha sstopped working have changed
Had the same problem just hit the red button in the top pannel and re-sync
Feb 21, 2010 | Nintendo Wii Console
Hi my wii remotes arent working please help
Possible scenarios:
Out of battery:
Solution:
Replace batterries
Connection has been intercepted:
Solution:
Take the back off of the remote and then go to the Wii and open the little compartment left of the Wii. Then press the red button on the Wii remote and console simultaneously untill something happens like, connection restored on the Wii screen.
Dec 30, 2009 | Nintendo Wii Console
The batteries went in my wii remote so i replaced them but now cant get the remote to work,,i"ve tried everything i could think of so now asking for your help,can you help please??
You may need to sync up your remotes to your console again.
If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console. Make sure to secure the wrist strap, and have fun!
Nov 24, 2009 | Nintendo Wii Console
Wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Jun 21, 2008 | Nintendo Wii Console
Remote malfunction
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Aug 14, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
234 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
