Question about Philips FWC550 Shelf System
My radio turns on but when you select cd,tunes,tape ect... the radio turns off and the ECOpower RED lil light turns on the radio turns off
  • Philips Master
  • 6,993 Answers
your player is having a power problem. A bad IC is the cause of this.
Take the player to a repairer, so that the bad IC can be replaced.
Good luck.
Posted on May 18, 2010
I have 2001Aurora Oldsmobile v8 every time I try n put a CD in the radio it goes in but don't play it keeps saying check CD it won't play the CD but it was working fine a Lil while ago
they do go off the Lazer then they need some Adjustment in the radio Stores to be fixed take it to your LOcal Shop for repair,s and Away YA Go Again Listening to the TUNES on the Road Again Thks
Mar 04, 2015 | 2001 Oldsmobile Aurora
Sound distortion on medium volume with radio, cd, aux, ect.
The problem is in the audio driver or output stage which is normally an ic semiconductor, it is recommended that a technician look at the stereo to assess cost.
Sep 24, 2012 | Philips FWC527 CD Shelf System
I have 29ltd love the radio i'm over the road truck. I reasonnly replace my old steel whip center load antenna put 4' k40 top load one.ran new coax 18' grey. I get the red ( ant) light comes on...
Check SWR with a meter, if its 1.1 to 1.5 then its fine no matter what the light says. The light can be adjusted inside to not light up until its very high(Its adjustable with a Variable knob inside) Get a Cb shop to check it out. I'd go for LIL Wilson 500 or 1000 antennas, I hear they are superb.
May 11, 2011 | Cobra 29 LTD CB Radio
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
Honda Radio button lights do not illuminate
were the lights working before?
sounds like a defective radio.
Nov 23, 2008 | 2002 Honda Accord
Denon UDM3 SHELF SYSTEM
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Dec 14, 2007 | Denon DM-33 Shelf System
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Philips FWC550 Shelf System Logo
74 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
