Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
My g.e.ice maker does not put out near the amount of ice that it is supposed to at least so i could have a cold drink once a day id be satisfied with 10 ice cubes in aday would be nice a month ago i was bagging ice to put away and now i wish icould just fill one glass a day
  • GE Master
  • 8,220 Answers
If you clean up the coils down under the ice box could work better.If you change the water filer or water valve or both you might see an improvement.
GE ICE MAKER service manual
Posted on May 11, 2010
How do you make iced hot chocolate?
  1. Pour milk into blender.
  2. Add hot cocoa mix and ice.
  3. Blend first at low speed and then high speed until ice is finely crushed and slushy.
  4. Pour into tall glass and top with whipped cream and a dusting of hot cocoa mix, if desired.
  5. Serve with a straw and enjoy!
  6. P.S. This recipe was originally posted using small ice cubes. At our shop we have a commercial blender that has no problem getting through these. Since most people have regular blenders, I have changed it to crushed ice.
Feb 25, 2013 | Wine & Spirits
When making iced tea, what measurements of tea should I use?
Use the suggested amount of tea noted below:
3 Quarts - 5-7 bags or 2-3 Tbsp. of loose tea
2 Quarts - 3-5 bags or 1-2 Tbsp. of loose tea
1 Quart - 1-3 bags or 1/2-1 Tbsp. of loose tea
Sep 02, 2011 | Philips Senseo HD-7810 Coffee Maker
No water to ice maker
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Oct 04, 2009 | U-Line Icemaker
My uline BCM45A ice maker is cold but does not make ice
This unit work on the thermostat. When the temperature gets between 10 - 15 degrees it will satisfy the control then turn the compressor off and icemaker will advance. If the control is set too cold then it will never satisfy the control. 1st make sure the thermostat is at the warmest setting. When the compressor cycles off look to see if the icemaker is advancing.If no then replace the control.
Sep 15, 2009 | U-Line Icemaker
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
My freezer will not go through the harvest cycle. The ice tray fills with water, just will not harvest. I have continuity through what I assume is the temp sensor when cold, but where is that supposed to...
THE HARVEST CYCLE begins when the freeze algorithm (programmed into the electronic control board) has been satisfied and the sensor arm is out or fully extended. If the arm is in the “in” position when harvest is to begin, a delay of 3 minutes will be added once the arm is moved to the extended position to allow for drawer type ice buckets to be removed for this amount of time without starting a harvest cycle. This 3 minute delay will begin again if the arm goes back to the “in” position anytime during the delay period. This arm is spring loaded to go to the “out” position unless it is being held in the “in” position by an obstacle such as an ice cube.MORE
Jul 22, 2009 | Refrigerators
ICE MAKER GETS COLD-DOES NOT PRODUCE ICE
Hi
Try turning the thermostat to a lower setting. (warmer) It might be set too cold and the thermostat isnt being satisfied. Usually this is all thats wrong with it. Temperature in bucket between 10-15 degrees.
Jun 08, 2009 | U-Line Icemaker
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
