Question about Toshiba Satellite A100-S8111TD Notebook
INSTALL WINDOWS DEAR SIR, MY CD DRIVE DOESN'T WORK, I HAVE AN EXTERNAL CD DRIVE BUT IT CANT SUPPORT BOOT DEVISE. I HAVE TO FORMAT MY LAPTOP. HOW I CAN ENABLE BOOT MY EXTERNAL DEVICE?
  • 3 Answers
It could be three thing first and it's easy it could be a virus second the motherboard maybe you spelt some juice that mass the wires up thired update the divers and the bios
Posted on May 11, 2010
I cant format my C400 with a pen drive
If you're tryng to format the HDD on a Dell latitude C400 (or install an OS), this thing will not boot to any USB devices (flash drives, pen drives, external USB cd-rom drives, etc.) - just ain't gonna happen since the BIOS doesn't support such boot devices. The only thing it'll boot to is (1) docking station, and (2) a Media Bay optical drive.
Sep 01, 2011 | Dell Latitude C400 Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
I cant format my laptop elitegroup A535
Try to use another windows installation cd/dvd or make use of an external cd drive to boot from it and format system.
Oct 07, 2010 | EliteGroup ECS A535 Notebook
Dear Sir I have a problem with ACER EXTENSA-5210 Laptop , I cant format my hard disk and windows instolation plz what can i format my laptop
of course you can format your laptop's hard disk. but you cannot do it while you are running windows. to format your hard disk and install a fresh copy of windows, you need to have 1) Windows XP CD Installer and 2) a valid cd key to complete your installation
How?
Load the CD Installer to your CD/dvd drive and restart your windows. When booting, your laptop recognize a bootable CD so it boots from there and not from your hard disk. Just follow the on-screen instructions to proceed.
Oct 15, 2009 | Computers & Internet
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
IBM laptop cant load XP from externall CD drive
If you have a floppy drive on it you are in luck.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310994#XSLTH3135121122120121120120
That would be the most straightforward way to do it.
If not.
Are you able to boot off the external CD?
If so there is another way using the PE , preinstallatoin enviroment.
If not , you said you formatted it externally , which I assume means you have either a 2.5 to 3.5 IDE adapter or a USB to IDE adapter and another PC to format it with.
If you can hook the drive to another PC , you can do the install there , change some hardware settings , run the SYSPREP utility and swap the drive back into the laptop.
Mar 04, 2009 | IBM ThinkPad T23 2647 Notebook
Install os,cd drive not working
You can hook two computers together using a crossover cable. They may have them at radio shack, if not you can find one on the web for cheap. Then you can put the install in one cd and have it install in the other computer.
Jan 07, 2009 | Dell 2600 Notebook
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
