Question about Asus Eee 701Sd Notebook
It starts up than the screen turns on then off and then keeps doing this procees if i leave it on what do i?
  • 3 Answers
Try to change the display driver if not the motherboard driver
Posted on May 11, 2010
How do I replace a fuel pump for a 98' ford explorer
you have to drop ur fuel tank there is about 6-9 screws on top of tank take them out and un plug wires going to it pull it out there it is ur fuel pump put new one in the same way you took ur old one out put it back together turn ur key to on postion give it a few seconds then try turnning it over a few cranks if it dont fire keep repeting this proces and it will start good luck
Dec 17, 2013 | YouTube Videos
Fue pressure regulater
first thing you should do is get the code for what the vehicle say's is wrong..you can get a general diagnostic code by first locating the check engine light then put your key in the ignition (do not start the vehicle) now turn the key to the on position four times on the last turn leave the key in the on position and start counting how many times the check engine light blinks there will generaly be a two or three part code so there will be a slight pause in the blinking when this ocurse start the count over agian and so on..i suggest that you repeat this proces several time so that you know that you've got the correct code..then go online and find a jeep website or chrysler website that has a display of the codes and compair yours to that list to find what the diagnoses is...note sometimes the diagnosis is fairly vague..you may also try just replacing all of you fuel relay switches and the auto shutoff relay switch...also could just be a cloged fuel filter..but try the code first otherwise all your doing is fishing for the problem and using your money as the bait...
Nov 02, 2011 | 1987 Jeep Cherokee
Host Procees as stopped working
It appears that the Windows is corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Dec 27, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
How do i change the administrator password on a gateway g6-233m, when the previous owner never gave me the old password?
Restart the computer and during the boot up procees hold down the F8 key and you will be prompted with a black and white screen that will give you the option to boot into safe mode, Once your desktop loads go to start, Control Panel, User accounts and change your administrator password. Hope this helps.
Jun 21, 2010 | Office Equipment & Supplies
I want to restore my dell netbook to factory
FOr this if you have windows vista
1. Restart your compuetr and the moment you see something on screen start tapping F8 key slowly and keep tapping utill you see a black screen with some optioons in white color.
2. The first option will be Repair your computer. Highlight it and select that by hitting enter.
3. It will take you to screen where you will find some option where there would be 6 options and you have to select the last one.
4. It will ask you for confirmation of data deletion you can proceed if you dont want data.
5. It will take 15 to 20 mins to complete the procedure and the system will restart.
If you are using windows Xp
1. WHen you restart the computer you have to press and hold Ctrl key and then you have to keep tapping F11 key and it will take you to the same screen where it will ask you for data deletion.
This is how you can proced on.
thanks
Deepak
Oct 28, 2009 | Dell Computers & Internet
Taking movies
well there may be a promblem with the battery or maybe it is the shaking but if its a battery promblem keep turing it on until it wont turn on agian charge it and repeat this procees 2 or 3 times.
Nov 02, 2008 | Cameras
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
SanDisk Initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 03, 2008 | SanDisk Sansa m230 MP3 Player
Asus Eee 701Sd Notebook Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
