Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
COBRA 29 NW LTD CLASSIC
WITH NO MIC ON THE RADIO, WHEN YOU TURN THE RADIO ON, IT WIL BLOW THE FINAL RIGHT NOW. IT GOT TO BE COMEING BACK THROW THE RADIO SOME HOW, HELP CBDUDE
  • Dean Dishman May 11, 2010
    Is the final Popping? sounds like a dead short somewhere. If it has taken the final out it probably took out the driver and pre driver all will need to be replaced .
  • 90 Answers
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Posted on Jul 20, 2008
SOURCE:
When i try to calibrate my cobra 29 ltd classic the needle will not go to the right
make sure you have your radio set on CAL and then adjust the knob that says adjust .Turn it all the to the right then bring it back to the set point on the dial then un key the mic,move the switch to SWR , key the mic and that is your reading. Do this on channels 40 - 1 then 19. Make sure you write down the readings for each channel. The adjust your antenna from there.
Jul 05, 2014 | Cobra 29 LTD CB Radio
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd nw classic
Yes, Do Not Turn Up Too 500's Way Too Dangerous, The Problem Might Be That Inside Some Cords May Be Rubbing Wrong Or, You Have A Short Cord, If Not Any Of That It Is Probally Broke
Aug 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
166 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
