Question about Canon P1-DHV Calculator
How do I set the date and time on a canon P26-DH III calculator
SOURCE: Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Posted on Feb 05, 2008
SOURCE: Canon P100-DH Calculator manual
Press the "calendar/clock" button to display the calendar. Then press the "=" sign to get the display to flash and you can enter the numbers for the date. Press the "=" sign again and you have set the date.
Press the "calendar/clock" button once or twice to display the clock. Then press the "=" sign to get the display to flash and you can enter the numbers for the time. Press the "X" button if you need to change the AM to PM or PM to AM. Press the "=" sign again and you have started the clock. Do this again if you need to start the clock again at zero seconds.
Posted on Sep 29, 2008
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
SOURCE: installing new paper in canon p26-dh ii
looked over P1-DHV Calculator found slot on top back middle of machine where paper goes in easy then up into machine with paper feed
Posted on Jan 06, 2010
SOURCE: How do you load the printer paper in P26-DH III
The feed slot is located in the rear of the unit. You don't feed the paper down from the top-there is a paper slot in the rear; just cut the paper at a 90 degree angle and feed it into the rear slot-very easy. I tried to feed it down from the top for twenty minutes and then discovered the other slot. Good luck
Posted on Mar 22, 2010
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Mar 18, 2010 | Canon P1-DHV Calculator
How do you set the date and time on the P26-dh
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Mar 15, 2010 | Canon P23-DH Calculator
Jan 30, 2010 | Canon P1-DHV Calculator
How do i put recept paper in my canon p26-dh 111
how to replace the ink roller on a Canon P26-DH 111
calculator?
Jan 23, 2010 | Canon P1-DHV Calculator
Installing new paper in canon p26-dh ii
Jan 05, 2010 | Canon P1-DHV Calculator
Setting the date and time
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Jan 08, 2009 | Canon P23-DHIII Calculator
Can't set date
Download the user manual (P23-DH III) from here:
Nov 15, 2008 | Canon P23-DH Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
How to change the roller ribbon on my Canon P100-dh calculator?
Jan 10, 2008 | Canon P100-DHII Calculator
Canon P1-DHV Calculator Logo
144 people viewed this question
old marine
old marine
