Why would it have a switch? Fuel cut off switches are found on race cars. The closest thing you probably have is a fuel pump relay. As for the location of that, this thread is good: http://forums.nicoclub.com/1984-300zx-fuel-pump-relay-location-t567634.html
Check the fuel system inertial switch (collision cutoff switch), located in the trunk. It should have a reset button. Push it. If that does not work, try BYPASSING the switch to see if the pump works then. If it does, replace the switch.
It could be a couple of things. I first guess is to check the fuel filter. If it has not been changed out within 15-25,000 miles deposits that within the gas tank has restricted the flow and will cause a hesitation or very rough idle. Now the desposit could have surface close to the injectors restricting the flow. Second, tune-up ( distributor cap and button, spark plugs, wires, etc). Third, check all you fuel hoses leading (especially leading from the fuel filter) to and from the engine.If they have never been changed, I would do so. Hope this a start of resolving your problem.
inside the door pillar , behind passenger door . sorry no picture . strange location but thats what the manual says . for 87 nissan 300zx . hope thats a fix ya !
