When I plug in my t.v. (product # MX-26X3, Model # l2614XW02) I get vertical lines when ever i turn the channel. I also get no sound. Is this worth fixing?
  • 13,434 Answers
Here is the official MAXENT tech support
Technical Support
To better assist our value customers, please call us during our operating hours or email us.
Toll Free Number: 1-888-373-4368
Hours of operation: Monday - Frday, 8:30am - 5:30pm PST
To email us, please fill out the Contact Us Form.
Il get back to you in a moment.
Posted on Mar 28, 2008
  • 1 more comment
  • Ekse Mar 28, 2008
    Q: I can see the picture, but I cannot get any sound?
    A:
    Some things you may want to check on the Maxent Product.
    If you are using the Composite (Referred to as AV1 or AV2) input you must connect the Red and White audio connections on the right next to the Video input. You would have a total of 3 connections running from your source (DVD, VCR, etc.) to the back of the monitor (Yellow for Video, Red for Right Audio, and White for Left Audio). Please refer to pages 14 and 15 of the user manual for additional detail.
    If you are using the S-video (Also referred to as AV1 or AV2) input you must connect the Red and White audio connections on the right next to the S-Video input. The S-video input is a single black multi-pin connection. You would have a total of3 connections running from your source (DVD, VCR, etc.) to the back of the monitor (Black for Video, Red for Right Audio, White for Left Audio). Please refer to pages 14 and 15 of the user manual for additional detail.
    If you are using Component Video input (Component 1 or Component 2) you must connect the Red and White audio connections on the right in line with the Component Video inputs. You will have a total of 5 connections running from your source (DVD, HDTV Receiver, etc.) to the back of the monitor (Red, Green, and Blue for Video, and Red for right audio and White for left audio (The Red and white for audio will be next to each other)). Please refer to page 15 of the user manual for additional detail.
    The Audio Out on the far right of the Input box is used only to send the audio from the selected source to an external device (Amplifier, etc.). This level can be fixed or variable depending on the menu setting (see page 48 in the user manual to set). Please select Fixed if you are connecting to an external source with a volume/level control, or select variable if the source does not have a volume/level control.
    Using the Remote Control for the Maxent, select the following:
    Press MENU
    Select SOUND
    Verify the Speakers are set to ON
    You may also want to verify that the source you are using has the audio enabled properly. You can sometimes verify this by connecting the audio from your device to another monitor or audio system.
  • Ekse Mar 28, 2008
    Q: There are faint lines when I am watching a program. What causes this?
    A: The rolling lines you are seeing are probably noise bars. Digital display monitors are more sensitive to extraneous frequencies that normal TVs.
    Noise bars are usually generated by an external device and are received and displayed by the monitor. These devices are electronic in nature and can be anything from custom lighting to other electronic components. You may want to try unplugging electronic devices in the same area as the monitor to isolate which external device is causing the problem.
    If you are getting these noise bars when using a cable box (or a standard VHF/UHF antenna) to view TV or just using the supplied coax cable line from your cable provider, verify there are no breaks in cable and that the coax is properly grounded. You may want to contact your cable company to have them verify this if you are unable to do so.
    The outer shell of a coax cable shields the TV signal from outside frequencies and noise. If the shield is not properly grounded, the shield will not isolate the TV signal and you will receive extraneous noise on the display. Also, if you are using any splitters in the coax line, verify they are also properly grounded and of good quality.
  • Ekse Mar 28, 2008
    If you need more asistance, let me know.
SOURCE:
I have a Maxent MX-26X3 Television and I cant get it to connect to the local channels when I plug in an antenna. What am I doing wrong?
Do you have a digital converter box? Its a smaller block square box that connects to the wall and the tv connects to the digital converter? I you do not have a digital converter that is most likely your problem. Not a gurantee but since they did the big digital signal switch, you now need these converters. Hope this helped
Oct 26, 2012 | Maxent MX-26X3 Television
How can i fix static on my maxent lcd tv
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
Jul 11, 2011 | Maxent MX-26X3 Television
Maxnet mx-26x3 tv toconnect toan HDMI input
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Jun 10, 2011 | Maxent MX-26X3 Television
My Flat Screen Maxent, Serial# 53525943816, model# L2614XW02, Product Name MX-26X3 is not working, do have volume and do have blue screen, can you help?
you can do a reflow the the image board and concentrate on the chip with a green heat sink, or if your a master solderer you can unsolder it then resolder it back on, these will fix this problem for a few months since maxent is no longer around.
May 12, 2009 | Televison & Video
Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Aug 08, 2008 | Maxent MX-26X3 Television
Maxent MX-26X3 MODEL L2614XW02
Tcon board issues or the cabling going in or out of it
Nov 30, 2017 | Maxent MX-27X1 27 in. HD-Ready LCD...
Maxent MX-26X3
More than probably is the LCD control board, but this one is coming with the LCD panel. Could be the main PCB too and I suggest you to call a tech for a exact diagnosys because the parts implied are very expansive.
Jan 26, 2008 | Maxent MX-26X3 Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Ekse
