Question about Philips FWC550 Shelf System
My radios does not stay on
My radio turns on but when i try to press a system botten as for tunes,cd or tape it turns off and goes to ECO power and it wont stay on. can you plz help me
    Genius:
  • 1,040 Answers
There is a mechanical problem.... So get it serviced.
but still try by setting out your gadget to factory defaults..........
Posted on May 11, 2010
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Nov 03, 2010 | Teac EX-CD3 CD Shelf System
I have the unlock code for my 99 saturn sl2 but i need the radio layout
Hello, you will need to enter your radio unlock code using these instructions.
  1. Press SEEK DOWN, SEEK UP, TUNE DOWN, or TUNE UP. The radio display should show 0000.
  2. PRESS SEEK DOWN to set the first digit.
  3. Press SEEK UP to set the second digit.
  4. Press TUNE DOWN to set the third digit.
  5. Press TUNE UP to set the fourth digit.
  6. If the code was entered correctly, the radio will display SEC (SECURE). The theft deterrent system for the radio is now active and normal operation may be resumed. If the code was entered incorrectly, the radio will display Err for 5 seconds and the LOC (LOCKED) will be displayed again. If LOC is displayed, repeat 1-6.
  7. If the correct code is not entered in 8 attempts, follow the next steps:
  8. 7.1. Turn ignition to ACC position. 7.2. Turn radio power switch OFF. 7.3. Wait one hour before repeating steps 1 through 7. If attempts to unlock the system are made before the one hour period is up, the radio will display INOP (INOPERATIVE). Continue to wait. If the ignition is not in the ACC position, power will never reset internally to allow itself to be unlocked. 7.4. After one hour, repeat steps 1-7.
Jul 03, 2010 | 1999 Saturn SL
My radio wont stay tuned in! when i turn the ignition off and leave the car when i return i have to retune the radio i have tried pressing the reset button what else can i try
Check the battery wire behind the radio it should not be connected or the fuse should be blown, the wire color in aftermarket stereos usually is Yellow
Mar 11, 2010 | Sony CDX-GT100 CD Player
Lost code for 1996 toyota prado radio l had the battery replaced now the radio displays a sec sign
for our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
SEC has now been removed, enjoy your radio!
Feb 08, 2010 | Car Audio & Video
Sony walkman fx281 says hold when I push AM or FM button How do I turn on radio?
Srt HOLD switch to Off position as shwon in below image so Radio will start work.
Thanks.
Feb 05, 2010 | Sony Walkman WM-FX281 Personal Cassette...
How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
Dec 12, 2009 | OEM Systems Car Audio & Video
I can not play my Honda CRV 2004 stereo system. Errors come up
The procedure for mostly all Honda CRVs are the same as follows:
1) Turn off your radio with the ignition switch turned on.
2) Press #1 and #6 on your radio simultaneously. While holding these numbers pressed in, turn on the radio and watch the console on the radio. It will display two sets of numbers which will switch back and forth like U251 1 and L362 2. Take these numbers down and call any Honda dealer with them. With these numbers, any Honda dealer will be able to get you the code. If you are lucky they may not charge you but it will be worth a small fee.
The dealer will give you a number like 42351 or so. Turn your ignition off and enter these numbers - then turn your ignition back on and your radio should come on. Keep fiddling with this procedure until you hit it right.
Good luck
Feb 19, 2009 | Kenwood Car Audio & Video
Philips FWC550 Shelf System Logo
85 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
