Question about Motorola Mobility S9 Headphones
Moterola wireless headphones not working with my iphone3g
My new moterola wireless headphone when paired with my iphone 3g wont change songs wirelessly and looses connection extremely often even when my head just turns a little bit
what is wrong and should this be the case?
    Master:
  • 519 Answers
I have the same problem, at the beginning they used to change the songs from my itouch but now the others work but the ones to change tracks. did u get any answers?
Posted on May 14, 2010
The iPhones do not have a2dp, so, changing tracks isn't supported. However, if you have your phone jailbroken, there is an app on cydia called Music Controls (or something similar), that will allow you to do that. I had the same issue, then purchased that app, now it works great.
Posted on Jun 01, 2010
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I can't find the pairing codes for my ns-bthdst
the code on the PC side should be 4 zero's, there is no code to set on the headphones side of things, just power the headphones on and on the PC set to serch for new devices.
Feb 17, 2011 | Insignia Bluetooth Wireless Headphones...
I cannot get any sound through headphones or internal speaker on my iphone 4 using apple remote which is paired with my home laptop windows 7 and my iphone .everything works ok except no sound when i play...
Using the apple remote app on the iPhone only changes the song on your home laptop with windows 7. To play songs through your headphones or internal speaker you have to use the iPod app that was preinstalled on your iPhone 4.
Feb 14, 2011 | Apple iPhone 4 Black Smartphone
My iphone wont connect to the bluetooth in my valkwagen golf car?
As I have learned the hard way the iphone's bluetooth is only to pair with wireless bluetooth headset and car stereo. You cannot connect to any other kind of devices. Also you must have Iphone Os 3.0 or higher to stream music to your car stereo. If it still does not work then the belkin bluetooth audio receiver should solve your problen
http://www.blueplastic.net/en/escuchar-musica-de-tu-iphone-via-bluetooth-conectar-iphone-a-radio-de-tu-coche-via-bluetooth/
Oct 04, 2010 | Apple iPhone 3G
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Pairing probs with insignia bluetooth wireless headphns to iphone, device is showing up on iphone, but no sound
have your put a new battery in your headphones.
they show 10 hours of continuous play so the battery may be charged enough to pair but not to power the headphones.
Change the batteries and try it.
May 12, 2009 | Audio Players & Recorders
Sound in left headphone only sometimes works
you can warranty them on there website. they will probably send you a new pair.
May 07, 2009 | Skull Candy SC-INK'D/Blk Consumer...
Motorola Mobility S9 Headphones Logo
283 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
ka4iup
ka4iup
john h
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
