Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I am using F5D7231-4 V2 in India and accidently instead of using a 220v to 120v converter just plugged in directly and from then on when I power on the wireless router, the LED of network port glows and wireless LED indicator doesnt. Nor can i connect 192.168.2.1 from computer. Do you think there is a hardware power problem ? can this be fixed ?
    Problem Solver:
  • 13 Answers
I think you said that you fed 220v into a 120v router. If so, it's fried.
Posted on May 11, 2010
Need directions on how to pull out the Armature of BOSCH CS20 and convert it to 220volts internally?
Buy a second hand step down trafo 230v to 120v to made it a sheaper project , its not worth for this kind of handpowertools to customize it.
On marketing technical reasons, there are no equivalent components for this model cs20 the armature is look a like a Makita armature some type of bosch tools are comparable with parts in several variations. but little differences on measurements.
Dec 20, 2016 | Bosch Saws
Hi, i have a dream machine sony ICF-c218 by mistak connected to 220v the original transformer is 120V & i also would like know the output voltage of this transformer so that i can change it 220V p
My self sushil from india pl.find the details
yellow-blue is 3.2 VAC
red-white is 4.2 VAC.
Clock is well functioning without frequencies difference error. I think the clock is using crystal for pulses generator instead of AC power supply frequency.
May 22, 2012 | Sony Audio Players & Recorders
I live in South Africa and my son has brought back a Panasonic shaver from the USA. Can our std 220v power outlet be suitable to charge the shaver? The power pack only mentions 120v input AC?
If the power supply that came with the unit says only 120V, you must use a voltage converter with the unit. If you plug the charger into your 220V system without a convertr, it will damage the charger
Apr 17, 2011 | Health & Beauty
I bought a WAHL 9854-600 Lithium Ion All In One Trimmer when I was in US a month ago. I charged it once when i was in US and then returned to India. Though the charge lasted for a long time, I am unable to...
The voltage in India is 22V. The unit you purchased in the US is for use with 120V. If you have plugged the unit into your 220V electric supply without a voltage converter to lower the voltage to 120V, you have damaged the charging cord and it will need to be replaced
Nov 23, 2010 | Wahl Health & Beauty
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Converting 120v AC adapter to 220v AC adapter
I live in the Philippines, but I've got relatives in the US who send me gadgets as gifts. I've had the same problem with my laptop before but when I called HP call center, they said that as long as it says there input 100 - 240V, then it's ok to plug it in a 110 or 220 socket. Here in the PH, we have 220V sockets, but Americans use 110.
Anyway, your phone says it can only be plugged to a 120V socket (max) so that means, you have to use a transformer (that's what we call it here. a black box-like thing) to convert the volts from 220 to 110. If you plug your phone directly, it might explode.
I hope i answered your problem.
Nov 27, 2008 | Lands Phones
How to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Aug 01, 2008 | Brother Sewing Machines
Ac adapter
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Jul 12, 2008 | Televison & Video
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
91 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
