Question about LG Computers & Internet
The picture is not steady. It floats - LG Computers & Internet
  • LG Master
  • 1,214 Answers
Look for the scart plug (if there is one)is in place.
I know that if the colour on screen is not right or if the sound is not good. Then it pays to start off by securing oneself that all plugs are plugged in where they belong.
Then I would look for "troubleshooting" in the manual.
Posted on May 15, 2010
Fuel leak from carburettor
No need to buy a new carb. Simply clean it and or replace the float needle valve. Check float level also after replacing the float needle valve. Most of the time the carb gums up and causes this to happen when sitting for a long time without being run. If you are going to store your bike for a while. Drain all the fuel from the carbs and gas tank before storing. You can also use a gas stabilizer in not setting up more than 3 months.
Mar 20, 2014 | 2011 Bajaj Pulsar 135LS
Ariston Problems
If you have to turn the water off at the mains it will probably be that the float valve rubber is worn out allowing water to keep flowing into the tank. Remove the float and the valve that it is attached to and replace the seat in the valve
Apr 27, 2013 | Cars & Trucks
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
My zzr is leaking fuel at a steady rate from the hose that empties out in front of the rear wheel, there is poor response from the throttle at low revs and does not hold idle. its as if its running far too...
It is flooding. Check for a float sticking or a needle and seat sticking open. It could also have a hole in a float that is it keeping open. (The float could be full of fuel and failing to float).
Jul 31, 2011 | kawasaki ZZR 250 Motorcycles
I have a 99 haley davidson sportster 1200cc and gas leaks from the carburator at a steady pace, why?
tsomething is sticking the float in the float bowl(bottom of carborator) sometimes you can tap on it lightly and it will unstic also may be a bad gasket always turn the petcock to the off position when noy riding
Apr 24, 2011 | Harley Davidson XL 1200 S Sportster Sport...
Just cleaned carb for 99 grizzly 600 and it runs for a min or so and then dies same problem happened before i cleaned the carb
Check for a steady supply of fuel to the carb. Could be a blocked or pinched fuel line. Very possible that the float needle and seat are worn, causing the valve to remain closed or partially closed. When this happens the fuel bowl runs out of fuel causing the engine to die. Then fuel trickles back in while sitting and slowly fills the bowl again, allowing the engine to restart. Also be sure that the float level is set properly and that the float pivots freely. Most small engine carb floats are set to shut off the fuel when the float rises in the bowl to where the flat surface on the float is parallel to the bowl mounting surface. If the float is set close to this, don't try to adjust it. If your float needle has viton (rubber like) tip, be sure that it is not deformed. Never press on the needle because it will deform the tip, causing the valve to stick open or closed. Many times you can buy just the float needle and seat either OEM or aftermarket.
Feb 03, 2010 | 2004 Yamaha TT 600 RE
Everytime I take a picture with my Nikon D40 the pictures are...
Try holding the camera steady for a couple more seconds after you snap the picture.
Aug 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Steady blue light, blinking lights doesn't heat up
I read in another posted solution about a magnet in the grey float that is in the water reservoir. I removed the grey float and rubbed on the front of the unit by the steady blue light and it apparently resets the sensor. Presto Magic! it worked! Machine back to normal and operating perfectly.
Jun 13, 2009 | Saeco Starbucks Sirena Espresso Machine
My mower will run for a bit then start dieing
Sounds like there may be trash in the carb. when the gas bowl is full it runs until the gas runs out then it dies. Take the breather off get it started and then put you hand over the intake on the carb. sometimes this will allow the trash to be sucked on through do this several times take your hand off before the motor shuts down and then do it again until you clear it up. If this does not fix the problem you can take the bowl off the carb an see if it is getting fuel with the float hanging down this opens up the needle valve to let gas fill the bowl. there should be a steady stream of gas coming out. when the bowl fills up the float floats up and closes the needle valve. If there is not a steady stream of fuel coming out with the float hanging down with the bowl off you may have to remove the float and needle valve and clean out the needle valve jet with something like a sewing needle. If you are getting gas steady and fire to the plug it should run.
Jun 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Computers & Internet Logo
37 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
