Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Cleaning I have a white Jenn Air stove.Manual says to only use liquid soap- no other cleaners and no abrasives. I am unable to clean cooked on stains using this method. Is there anything I can safely use to remove the baked in stains.
  • erin1980 Mar 28, 2008
    It is white. It is around the edges inside and out of the burners.
  • robert samples May 11, 2010
    where at on the cook top or the oven and is it a glass top
  • 83 Answers
Get some ceramic glass cook top claener.that will take care of it
Posted on Mar 29, 2008
SOURCE:
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Stains
    stainless steel polish will do this don't get too abrasive a cleaner though,there are different coarsnesses of the product
    May 15, 2010 | Jenn-Air JCD2389G Side by Side...
    Cleaning black cooktop surface - what products to use.
    It is recommended that you use a straight edge razor blade and push in one direction to remove anything stuck to the surface of a glass cook top. Stubborn, cooked on, substances can be cleaned by scrubbing with a light abrasive cook top cleaner and/or a green kitchen scrub pad. The green srub pads are considered non-abrasive and safe for cook tops. You can also use liquid dish detergent (such as Dawn) to break through grease and grime. DO NOT use steel wool, SOS pads, or any scouring powders. These products can permanently scratch or dull the finish on your cook top. If you have any questions please let me know. I hope you find this information helpful.
    Apr 27, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
    Stains in my thermocast sink
    Rinse after every use. Sanatize with Bleach once a month. Use a soft cloth or sponge and liquid soap to remove residue. Scratches can be buffed and polished with a liquid based auto polish to maintain High Gloss finish. Do not use abrasive cleaners which will dull the finish. If you have used the sink in a non-normal usage and stained it, it can not be repaired under most circumstances. If you have not voided the warranty, you may be eligible for a replacement from the company.
    Apr 16, 2009 | International Thermocast Corp Thermocast...
    Spot on Jenn Air smooth cook top stove with down draft.
    Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
    Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
    Having trouble cleaning splatters off Ingis Glass Top Stove.
    Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
    debrucepolish.com
    Jan 13, 2009 | Maytag MER5730 Electric Kitchen Range
    Suggestions for cleaning the genn air stove top JDR8895aas
    I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
    Dec 14, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
    Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
    190 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Thomas F. Schneider
    Paul Carew
    Ismael Rodriguez...
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
