Question about Kitchen Ranges
  • 1,314 Answers
Yes it only requires one 220 plug in you might have to change the breaker to match the amp rating or not and you can bake in both at the same ok
Posted on Mar 28, 2008
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
Kenmore oven/range doesn't work after turning power to my house off and back on.
a oven range is 240 volts , and will be a 40 or 50 amp double breaker make sure both breakers reset ,or you wont be getting but a120 volts to the range , not enough power .it looks like a single breaker but it is a double...
Jul 29, 2012 | Kenmore Kitchen Ranges
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
We were heating up our GE Profile JTP56 double oven to use for the first time after I installed a new Oven Electronic Range Control. It was all looking great...then, it all just went off. The breaker...
Hi--  Since you've gone this far already- let's check this stuff first.  >Power connections at bus block.  >L1 and L2 connections at control.  >Any ground connections.      Start with power off and visually inspect connections.  Bus block is difficult to access for live testing, but can be seen with bright flashlight.  Connections on board route all the power, so make sure all are tight.  Please acknowledge this post if info is helpful- have more if needed.  Thanks- Ed
Mar 25, 2010 | GE Profile JTP56 Electric Double Oven
Broken older jenn air front glass oven panel
We are Jenn-Air parts suppliers and have access to parts for your range. Please record your model number from underneath the unit by looking inside the cabinet.
Then contact us at: from 7 AM unti 7 PM CST and we will give you the price and availability of this front glass.
We look forward to hearing from you. Thanks, Ella
Jan 21, 2010 | Kitchen Ranges
Double oven... top works great, bottom has power but will not heat. No codes showing. Have had ohm meter on it and all is functional to elements. GE Profile model # JKP56BOA1BB, older model... maybe 1999.
Do you have 220 volts to the element. If you do then you have a bad element. If you don't then it is usually your erc (electronic range control) or your oven sensor. You need to test your oven sensor for the proper ohms, (should be on your wiring schematic), replace the sensor if you don't have the right ohms rating. You can also compare the upper oven sensor rating with the lower oven sensor rating. If your sensor is good then you need to check if your erc is sending 220 volts down to the lower oven element. Again you need to look at your wiring schematic(usually found in a sleeve behind the oven control panel), to determine which terminals to test. As always you need to be sure that you know what you are doing when you are working with live voltage. If you don't know how to work on live electical products you need to call a technician. It can be very dangerous. Good Luck, Appliance Specialists
Dec 14, 2009 | Ovens
My Jen air double oven freestanding range model series JDR8895 ELECTRICAL SYSTEM IS NOT working and I live in Panama can you help me???
If absolutely nothing is working the first thing top check is the electrical circuit breaker/fuse panel for the house. Make sure full voltage is going to the range.
Remove the rear panel where the wires come in to the range and look at the terminals. Something may be broken or shorted in there.
There are no fuses or reset buttons in this range that would stop the oven and the surface burners from working at the same time.
Nov 13, 2009 | Kitchen Ranges
Buying accessories for diplomat range oven
Fixya does not sell parts and is unable to identify sources.
Jul 15, 2017 | Kitchen Ranges
Thermador range (oven) is stuck in OFF mode.
I have exactly the same issue with the same model. Did you find a solution? Thanks.
Mar 10, 2009 | Thermador Kitchen Ranges
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
