When i use it for a couple min my mac freezez and says waitiing fpr debuging is on my computer
  • myers_steffa May 11, 2010
    it happens when i use reason adapted and some kernet version comes up what should i do
  • 4,924 Answers
If it is doing this each time you acces that program ..or on the browser..you have to save important files...into the other partitions ..(if it doesn't work to let you save files... Just connect the hdd to another Mac..and move the files from the main partition to the other for safe keeping ..)and reinstall the operation system ...This will be safer ..and much quicker than anything else..cause once the system bugged..(virus-ed) there is not much you can do ...it just freezes and you click something and wait for hours when the system is just looping and not able to achieve the commend..
Posted on May 11, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu May 11, 2010
    Than it is blocked by the anti-virus soft for debugging ...my advice is to delete the program fast ..and reinstall it clean ..or use a similar music program ..maybe the version is not supported or a change in your system configuration is in conflict ...But do not take any risk ...if it is bugged it may infect all your computer ..
    I think that uninstalling for Mac is just delete the folder with the program from the computer ..
  • Catalin Turcu
    like you explained the conflict is with the kernet ..than this is the issue ...choose which one you need and change the program or the domain ..
  • Catalin Turcu
    if the freezing is only on this 2 ..yo are lucky cause this may not be a problem with the computer after all...but with the conflict or the actual kernet when you access it ..
Cant get my dodge charger to crank i have key in hand but car says key not detected ?
the security system has issue--put key on position and waity 10 min-then try startn--if nuthn then disconnect batt and see if vehicle reboots--key slot or ignition switch may be bad--a scan can indicate the problem area
Nov 16, 2014 | 2011 Dodge Charger
Tip
How to solve safari slow script error
This error prompt is easily remedied, however, you'll need to access the Safari Debug Menu to do so. If the Debug Menu is activated, click on it in the Menu Bar and uncheck "enable runaway JavaScript timer. That ought to solve this problem.
If the Debug menu is not activated, follow these instructions:
Quit Safari
Open Terminal.app in your Utilities folder,
When the Terminal window opens, copy & paste the following command into the window:
defaults write com.apple.Safari IncludeDebugMenu 1
Click on the return key, you may be prompted for an admin password. If so, enter it.
Press "return".
When you see your Mac's name, it's done,
Quit Terminal
Restart Safari and go to the Debug Menu, following the suggestion above.
on Mar 17, 2010 | Apple safari
Locked out
Enter Recovery Mode on Locked Android devices
  1. In order to succeed with these steps, you will need access to a computer or notebook.
  2. Your handset and its USB cable should also be there.
  3. Your phone must have USB debugging option enabled.
  4. On your computer Android SKD must be installed -> learn how to install Android SDK on Windows or learn how to set up ADB on MAC OS X / Linux.
  5. Connect your device with the computer by using its USB cable.
  6. On your computer navigate through the Fastboot folder.
  7. There open a command prompt window.
  8. On the cmd window type: "adb reboot recovery".
  9. Good, now your handset will automatically enter in recovery mode menu.
Nov 17, 2013 | Kocaso Pink NB726A 4GB Android 4.0 1GB RAM...
How can I download music from my computer to my Samsung Galaxy Ace?
on your samsung galaxy go to settings, applications, development, make sure usb debugging is not ticked, go back to home screen, connect usb cable and a drive will open. preferably open the drive, open dcim folder, open media and paste your musics there. they should appear in your music player. Note your phone will only play mp3, wma and aac for audio and mp4, 3gp for video.
Nov 21, 2011 | Cell Phones
When i go on facebook it shuts safari down but i can go on any other website
You can try this solution if you are using a MAC.
1)Go to Macintosh HD, select Applications, then Utilities. Look for "Terminal". Once you open it, type this in: defaults write com.apple.Safari IncludeDebugMenu
2)Restart your computer, open Safari, and after "Help" on the toolbar, it should say "Debug". This is how you know your command worked.
3)After that, go to facebook.com, but under "Debug", click on "User Agent" and selects Windows MSIE 6.0.
It should open facebook, let you login and shouldn't close out Safari.
Hope this helps!
Apr 07, 2011 | Apple safari
My laptop turns itself off, sometimes in 15 min, sometimes 5h
change the power setting on your laptop to balance
Jul 11, 2009 | Computers & Internet
I have 1083 virus my pc freezez up what can i do tilmond@ymail.co
I hope you are saying that you have 1083 viruses on your computer. The "1083 Virus" is an actual chicken disease. Whatever you used to determine you have that many viruses should have a cleaning capability. If not download these: Dr. Web, Malware Bytes and Superantispyware. Run these and they will clean up your system. They're all FREE.
Mar 26, 2009 | E-Machines T6216 (827103077834) PC Desktop
My emachines computer starts up fine but freezez on the login user screen. i have bought the restore disks etc. but it will not read them because when i try to login it freezez too.
Are you booting from the restore disk? Shut down the computer, insert the cd in the drive and turn the machine on. It should then boot directly from the restore cd.
Aug 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
