LG DLE2516 Electric Dryer Logo
Posted on May 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power will not come on is there a reset button
Anonymous
Level 3:
  • LG Master 43,501 Answers
  • Posted on May 12, 2010
Anonymous
LG Master
Level 3:
Answers
43501
Questions
0
Helped
10844386
Points
101584
There can be many reasons why your dryerpower will not come on is there a reset button - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
MX300 waste ink full
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
tip
Reset Canon Pixma MP140
first you must know this information before starting:mabroukmedal_17.jpg
  1. Plug the printer to the power source
  2. press and hold the stop/reset button
  3. press the power button
  4. if the power led light, press two times the stop/reset button
  5. release the Power button and the stop/reset button
  6. wait, when the power led is green, press the stop/reset button 4times to reset wase ink counter.
  7. unplug the printer from the power source
  8. plug the printer again to the power source and power it on
  9. the counter is set to zero.
1helpful
2answers
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
1helpful
Hard reset button
Go for hard reset
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the LED lights in green, press the Stop/Reset button 4 times
3helpful
Errer code 5
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
4helpful
How to reset Canon mf4150
Hello and welcome to FixYa!
The manual reset Method for
Canon image CLASS MF4150 All-In-One Laser Printer is given below, Follow every step carefully:
  • Press and hold STOP/RESET button.
  • Press and hold POWER button.
  • Release STOP/RESET button without releasing power button.
  • Click STOP/RESET two times and then release power button.
Now your printer enter into service mode. Now
  1. Prepare paper on the paper tray
  2. Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  3. Press Stop/reset button for 2 times and then press power button, await till printer finished print again.
  4. Press Stop/reset button for 3 times then press power button to reset EEPROM.
  5. Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  6. Switch off the printer. if printer doesn't turn off, press button power until printer off.
You have done it
If any Further assistance required, I am here to help
I hope this solution helps you.
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) and testimonial will be esteemed.
Thank you for Using FixYa
10helpful
4answers
Canon MP145 error E27
  1. plug off power cable
  2. press and hold stop/reset button
  3. plug on power cable
  4. press and hold power button(still hold stop/reset buttn)
  5. still hod power button, loose stop/reset button
  6. press stop/reset 2X then loose power button, wait until 0 displayed
  7. press stop/reset 1X
  8. press power button 1X, printer will print 1 time
  9. press stop/reset 2X
  10. press power button 1X,printer will print 1 time
  11. press stop/reset button 3X
  12. press power button 1X ( no print proses)
  13. press stop/reset 4X
  14. press power button longer than before for turn off printer, if print not turn off plug off power cable
  15. turn on printer and error 27 will disappear
i hope this helpfull
thanks for using fixya
After replacing the ink cartridge printer still shows cartridge levels at 0%
Hi
You have to reset the cartridge
To Reset the HP Cartridges Works 100%
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Release power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the indicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Thanks
11helpful
How do I reset printer after putting ink cartridge in
To Reset the Canon Cartridges Works 100%
Relase power button
On the 3rd press the inicator should be orange.
Please rate my rsponse!!
3helpful
Reset To551 ink cartridges
  • Power off the printer
  • Hold the stop/reset button then press and hold power (for 5 secs)
  • Hold Power and release the stop/reset button
  • Press the stop/reset button twice
  • Relase power button
  • Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  • On the 3rd press the inicator should be orange.
  • Press the power button to set data
  • To set data remove cartridges then replace.
  • leave for 20 or 30 secs
  • Press the power button again to shut down
  • Then press power button to power up.
  • The printer will feed one piece of paper through
  • then set language and counrty.
  • Then ink should be reset
Please rate my sesponse!!
Thanks, SF
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
