Question about Whirlpool ET1FTTXK Top Freezer Refrigerator
Hello, I have a 2001 Whirlpool refrigerator, model ET1FTTXKT (top-mount freezer) which is no longer cooling in either the fridge or freezer. The motor seems to be working (I can hear it) and I can feel air pushing through the vents, but of course it's not very cold. What could be the problem? I have heard that it could be the compressor... sounds expensive.
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
Posted on Jun 28, 2008
mikedurland
  • 481 Answers
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Refrigerator/Freezer not cooling
Need your husband to unplug refrigerator and remove rear panel inside freezer compartment. Look to see if ice has covered evaporator coils. If so defrost them with a hair dryer and look over the defrost elements to make sure they appear good without burns or cracks. Let me know what you find, Thanks, Sea Breeze
Posted on Mar 26, 2009
  • 125 Answers
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
Posted on Apr 18, 2009
My refrigerator is Top Mount Refrigerator. The freezer (Top side) is working very well, however the fridge is not cool.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Whirlpool Refrigerators
The refrigerator is not working but the freezer is?
heatman101
Apr 13, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Freezer not as cold even when set on the coldest setting getting accumulation of frost inside freezer supposed to be frost free
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 21, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Leaking from top of refrigerator box
heatman101
Oct 27, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Top is not cold enough but the bottom seems to be ar lright
heatman101
Oct 25, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Whirlpool ET1FTTXK Top Freezer Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
