Question about Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W won't start - LED light blinking
When i press the on button the green LED light blinks about 15 times, then the red Standby light flashes. it goes through this sequence for 2 more times, then all three lights flash continually.
I previously replaced the capacitor when it wouldn't start and it worked for well over a year now without problems.
  • Samsung Master
  • 5,138 Answers
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
Posted on May 11, 2010
  • ladywinn
    ladywinn May 11, 2010
    Lamp needs to be replaced if Fans are OK. Mats has them for 99.00 1-800-628-1118
The problem with my samsung model hl-t5076s there is three flashing lights one red an two green. The red light flashing is called stand by temp an the two other green light one is time an one is lamp
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 19, 2016 | Samsung HL-T5076S 50 in. TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Televison & Video
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
HL-S5679W won't start three light blinking
There is no lamp on this TV.. Your issues sound like a bad DMD board or bad capcitors on the power board. Remove the power board and inspect it.
Jun 21, 2009 | Samsung HL-S5679W 56" HDTV
WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Jun 01, 2009 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W No video No sound
Jan 22, 2009 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W 56" HDTV Logo
1,037 people viewed this question
Jerry Greenberg
Jerry Greenberg
