Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
How to add in javascript?
3+1
3 and 1 is input from the user then output will be 4
  • 20 Answers
Var a=promt(“Enter first value to be added”);
a= parseInt(a);
var b=promt(“Enter second value to be added”);
b= parseInt(b);
var c = a+b;
alert (“Result is” +c);
Posted on Jun 17, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    Tip
    How to Solve the Javascript Void(0) Problem
    Many internet users face this problem when they try clicking a link and see this error code on the status bar of the browser which doesn't allow the link to work. It is actually an error message that occasionally appears in a web browser when you face a problem loading a JavaScript from a webpage. Though this error message pops up on various occasions but the actual reasons could be different for different users, and resolving these problems is necessary by knowing the most possible reasons for this error message.
    1- The major cause of this error message is the Popup blocker blocking the JavaScript while stopping the windows which open up as the advertisements on various sites. Resolving this problem involves making changes in the preferences of the popup blocker based on your requirements and thus disabling the popup blocker. One can even download another anti popup software instead or can read the product reviews of popup blockers to assess if they really cause these error messages.
    2- The malfunctioning of the web proxy servers (which are used for accessing the various banned websites) can also block the various scripts in the process. This problem can be avoided by not using the proxy server itself or using a proxy server that functions better and do not interfere in the downloading of various scripts. Also check for the compatibility of the proxy server with various web pages and scripts.
    An improperly written JavaScript could also lead to this error message. The solution lies in notifying this error to the webmaster who in turn must rewrite the JavaScript.
    3- The JavaScript might be disabled in your browsers, and this needs to be enabled. To enable this in IE, go to scripting tab of the security option in the Tools menu under the internet options; and to enable this in Firefox, go to Tools menu and enable the JavaScript option in Web features.
    4- Web browser implementation of JavaScript might also be broken in some cases, and this requires the switching or simply the up gradation of your web browser.
    There is this simple way where you can really avoid "javascript:void(0)" error message at the first instance because we know that this "javascript:void(0)" can cause certain browsers to really present your web pages in unusual ways, and since the "javascript:void(0)" statement is often occurred when a link has no URL attached to it, and the browser doesn't understand how to react and returns the error message. So for this, instead use the "return false;" statement to let the browser not to look for the URL. Try opening the document in any text editor; Locate the "javascript:void(0)" references within the document, Replace the links with the (#) symbol with the syntax ".", Add the "return false" declaration to the statement that would make the whole link reference to appear as a Link. Replace the "callFunction()" with your function name; Save and close the file finally.
    on Jan 12, 2010 | Computers & Internet
    I need a code of a simple login form with the output
    <?php
    require("db/config.php");
    session_start();
    if(isset($_POST["btnLogin"]))
    $nm=$_POST["txtUid"];
    $pas=$_POST["txtPass"];
    $q=mysql_query("select * from userinformationtb where user_id='$nm' and password='$pas'");
    $data=mysql_fetch_array($q);
    $_SESSION["seid"]=$data["user_id"];
    // session_id();
    if($nm==$_SESSION["seid"])
    header("location:php/home.php");
    //echo "valid";
    else
    echo "invalid";
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    <title>Untitled Document</title>
    <link href="../css/style.css" rel="stylesheet" type="text/css" />
    type="text/javascript" src="js/script.js">
    type="text/javascript" src="js/cufon-yui.js">
    type="text/javascript" src="js/arial.js">
    type="text/javascript" src="js/cuf_run.js">
    <link rel="stylesheet" href="css/validationEngine.jquery.css" type="text/css"/>
    src="js/jquery-1.8.2.min.js" type="text/javascript">
    src="js/jquery.validationEngine-en.js" type="text/javascript" charset="utf-8">
    src="js/jquery.validationEngine.js" type="text/javascript" charset="utf-8">
    jQuery(document).ready(function(){
    // binds form submission and fields to the validation engine
    jQuery("#frmLogin").validationEngine();
    </head>
    <body>
    <form id="frmLogin" name="frmLogin" method="post" action="">
    <table width="548" border="0" id="txtbrder">
    <tr>
    <td width="90" height="">Enter User Id </td>
    <td width="152"><label>
    <input name="txtUid" type="text" id="txtUid" class="tnm validate[required,custom[email]] text-input" />
    </label></td>
    <td width="56"><div align="left">Password</div></td>
    <td width="154"><label>
    <input name="txtPass" type="password" id="txtPass" class=" tnm validate[required] text-input validate[required,minSize[6]] text-input" />
    </label></td>
    <td width="74"><label>
    <input name="btnLogin" type="submit" id="btnLogin" value="LogIn" style="background:#0000FF;color:#fff;"/>
    </label></td>
    </tr>
    </table>
    <a href="php/userinfo.php">Create New Account</a> &nbsp;&nbsp;&nbsp;&nbsp;
    <a href="php/forgotpassword.php"> Forgot Password ?</a>
    </form>
    </div>
    </body>
    </html>
    Oct 31, 2013 | Computers & Internet
    I want to go back to classic email, but it has not
    Hello
    You just need to turn off the Javascript of your browser. Login to your yahoo mail then Follow these steps
    1- If your browser is firefox do the following
    2- Open TOOLS -> OPTIONS -> CONTENT, click on "DISABLE JAVASCRIPT".
    3 - press F5 or reload your browser screen
    4 - Follow one step instruction on your screen
    5 - After that Enable the Javascript again. By going to Step 2
    1- If your browser is Internet Explorer do the following
    2- Open TOOLS > INTERNET OPTIONS >> SECURITY. In security click "CUSTOM LEVEL" -> disable active scripting in the scripting section.
    3- press F5 or reload your browser screen
    4- Follow one step instruction on your screen
    1 - If your browser is Safari
    2 - Open SETTINGS>click PREFERENCES>>click SECURITY>>Uncheck ENABLE JAVA and ENABLE JAVASCRIPT
    3 - press F5 or Reloard your browser screen
    Sep 07, 2011 | Yahoo Mail
    How the swich yahoo mail classic mode
    Sep 05, 2011 | Yahoo Mail
    I cant open my inbox or contacts or anything. i also want cassic yahh. HELP
    Sep 04, 2011 | Yahoo Mail
    How can i go back to my old yahoo mail version
    Sep 02, 2011 | Yahoo Mail
    How many watts is a tristar 120?
    A Tristar CB radio cannot legally exceed 4 watts of transmitting power.
    You can add anetnnas in order to increas the "gain" to have the equivalent of much more transmit power.
    Microphones aren't measured in watts.
    The "impedence" (amount of resistance) is the important measure.
    Sep 30, 2009 | Astatic 636L Noise Canceling Microphone...
    How do I get my local channels from my VCR.
    If you have a cable or satellite converter all inputs are converted to channel 3 or 4. If your vcr is attached to this output you will only get whatever the converter is tuned to. If you have cable, try connecting the cable that's now on the input to the converter to the input of the vcr and then add the channels automatically. However, the converter also descrambles premium channels, so you cannot get them into the vcr without going through the converter first, and some digital cable channels will not work on all vcrs. If you use the converter, always leave the vcr on channel 3 or 4 or use the converter video/audio outputs. You will not be able to record one channel and watch another without some additional hardware including an rf switch, rf splitter, and more cables.
    Dec 04, 2007 | Zenith VCS442 VHS VCR
    ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
    114 people viewed this question
    Top ArcMedia Computers & Internet Experts
    Computer Links
    Robin Hill
    Robin Hill
    Mike
    Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
