Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kemore coldspot no ice?
5 yr old Kenmore Model number 106.53392300 has stopped making ice. The water supply to the door is still working. I poured water into the ice maker manually and it made ice but did not dump it into tray? What is the problem? Should I get a complete new unit?
  • Anonymous Mar 12, 2014
    Kenmore Coldspot 10650782001 Ice maker driping water from tray on bottom of ice maker, but makes ice ok.
  • Anonymous Mar 17, 2014
    Water is pouring from the icemaker
  • 1,314 Answers
No you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Mar 28, 2008
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
My Ref.wount make ice
I have a friend who has a kenmore coldspot Model# 7028999 Serial # EJ5040321 and it won't make ice there is water to the coldspot from the angle stop. A new pump was acquired and installled, but no water reaches the ice cube tray area. When ewater is poured into the ice cube tray area by hand, the ice cubes are made and the machine dumps them into the ice holder. What is the reason for no water from the angle stop to the ice tray? could there be an electric switch in addition to the pump device? Bob 512-762-4585
Apr 26, 2008 | Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 106.53552201
refrigerator works for a day and then quits working
Feb 04, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
457 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
