Question about Huffy 16 in. Boys Diego Single Speed Bike. Blue
Remove the pedals from a boys huffy bike
How do I remove the pedals from a boy's huffy bicycle?
  • 21 Answers
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
Posted on May 14, 2010
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
How do u put the front wheel on the Huffy Cars Lightning McQueen 16 Boys' Bicycle
back off the nuts and washers up on the wheel axel. Place the wheel between the forks positioning the axel in the slots. Replace the washers and nuts and tighten with a wrench
Dec 25, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
What is the size of the bolt on the pedal, the thread on the pedal is damaged and will not screw onto the bike what do i do
If you are good, you can file the threads on the pedal to remove the damage and even reduce the size of the first few threads just to get the threads to start into the hole. Once the first few threads start in, the others should follow.
Dec 24, 2010 | Huffy BMX 20" Boy's Rock It Bike
What is the size of the thread of a standard bike pedal?
There are 2 standard sizes:
Standard one-piece cranks 1/2" x 20 tpi
Standard 3-piece cranks 9/16" x 20 tpi.
The Right Pedal (gear side) has a normal thread, the Left has a reverse thread.
Dec 21, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
I need to know how to take a chain off without breaking it please
Pull the chain out slightly, away from the bicycle frame, at the bottom just behind the front cog wheel (attached to the pedals). While holding it out turn the pedals backwards and the chain will come off.
Sep 04, 2010 | Huffy BMX 20" Boy's Rock It Bike
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
How do I get a replacement for a Disney Cars Huffy bike pedal?
You can find replacement pedals on amazon. The cheapest (with most positive reviews) is Avenir Resin Pedals. Just chose the size, and enjoy. cheersget-replacement-disney-cars-huffy-bike-uh3jsoynacgcqh0wcsujgpyu-2-0.jpg
May 26, 2009 | Disney Cars 16-Inch Boys BMX Bike
Huffy 16 in. Boys Diego Single Speed Bike. Blue Logo
1,403 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
