Question about Dometic RM2652 Refrigerator
Dometic RM2662 won't light on gas
Hi, We have a Dometic RM2662 refrigerator in our 2007 Bigfoot trailer. Our unit was under the recall and we had the work done by a local dealer. They could not get the unit to light on the gas setting, but it worked fine on electric. They recommended replacing the main circuit board. Just after we brought the unit home, we discovered that the converter had malfunctioned and had cooked the battery. They decided that this was probably the cause of the problem as this would keep the flame from lighting. We have replaced the converter with a Xantrex True Charge 2 charger, redone our battery setup and, electrically, everything is peachy. The refrigerator, however, still will not light on gas. We have even tried lighting is manually, as instructed by them (didn’t know you could do this!). Do you have any ideas? Should we change out the brain? Any ideas would be appreciated. Bruce R. Beasley bruce@ressfc.com
    Top Expert:
  • Dometic Master
  • 5,743 Answers
Change ignitor or possible bad board
Posted on Oct 14, 2017
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
SOURCE: I had to replace the WFCO power converter, as it
RVIA
Recreatio Vehicle Industry Assocition
http://www.rvpartwholesaler.com
Dometic 9108677537 A&E Carefree RV Awning Pull Strap
Dometic 3307834.006 A&E Carefree Window Awning Pull Strap 28"
WFCO 8955 55 amp converter. New w/ warranty! US Seller.
WFCO 9855 55 amp deck mount converter. New w/ warranty!
Posted on Mar 12, 2011
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
SOURCE: dometic rv refrigerator
I was having the same problem as sallyfixit. After the recall on the Dometic RM2652, I was problem shooting to fix it. I found that you should check the wiring on the thermocouple to make sure it is wired correctly. If the on light, the check light and the interior light is still working but not cooling, replace the thermostor. This fixed my problem.
Posted on Jan 18, 2009
SOURCE: dometic rm2852 does not run on gas
So, the solution was simple but not obvious: the heat probe and the igniter are one and the same item, and all we had to do was bend the probe/igniter closer to the burner. After we did that the refrigerator started to behave properly.
Oddly enough, the repair manual for the refrigerator shows a igniter with a heat probe above it: the is not how the refrigerator is built.
Posted on Mar 24, 2009
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
Need instructions on how to light a rv Dometic refrigerator-
Go to this link and download 2600 PDF, last few pages are operation.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Operation--Installation-Manuals/
Jun 08, 2010 | Dometic RM2620 Refrigerator
RM2652 Refrigerator: I have a DM2652 model Dometic RV refer. It is leak...
Dometic Voluntarily Expands Refrigerator Recall
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The new recall focuses on models manufactured between June 2003 and September 2006.
To see if your unit is on the recall list & what to do, try the link below.
If your unit is on the list, DO NOT run your refrigerator on propane until the kit is installed
http://www2.dometicusa.com/recall.php
May 18, 2010 | Dometic RM2652 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Why is it difficult to light our dometic refrigerator, when using it on propane?
Hi: In my travel trailer I find it is easier to light my Dometic if I bleed the lines by starting my stove top. It uses a lot more gas to get lit and floods the lines with propane. Your fridge uses such a small amount of gas it takes a long time to bleed the line to it. Don't focus on just the oven.... run any propane appliance on the way to it first. I hope this helps, Jeff
Jun 12, 2009 | Dometic RM2620 Refrigerator
Dometic rm2652 recall
You wll see a metal shield around the burner tube, a dealer has to do the recall as far as I know.
Sep 14, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
479 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
