Question about Sharp AL 1631 Copier
Code "L" appearing after toner replaced
I work in a busy dental office. after replacing the toner an L appears on screen. any idea?
tom
  • 2 more comments
  • Anonymous Apr 03, 2008
    I changed my toner and the toner is in all the way and the door is completey closed. I am still getting an L on the screen.
    Please advise.
  • masonplus Apr 03, 2008
    door is closed and the toner is in all the way. Still getting an L on the screen.
  • screwyou Apr 06, 2008
    Turn on Copier. warms up. hear noise like gear slipping, power reduces and indicator switches between L and 1. No buttons function. Open side door and fromt door remove toner cartridge and drum. Replace and close doors
    Same thing, flashes between L and 1.
  • radicalrod May 02, 2008
    I do have the same problem. I keep hearing that grinding noise after I turn it on. then the L comes on the screen. HELP!
The "L" light indicates that the "scan head locking system" is in the lock position. It is located under the document glass (where the copies are dispensed) just turn it from the lock to the unlock position and it should reset the light
Posted on May 07, 2008
  • 3 Answers
HI: YOUR TONER DOOR MAY NOT BE CLOSED OR THE TONER MAY NOT BE ALL THE IN .
Posted on Mar 31, 2008
6ya staff
SOURCE:
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Canon error code E000066-0002
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Sep 01, 2014 | Canon Office Equipment & Supplies
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Sir i have toshiba e studio 212 machine when i on her empty toner replace toner appear the msg on screen what is the solution
Need to go to an office products company and purchase a toner cartridge. You might be able to have your toner cartridge refilled for half the cost of a new cartridge $80.
Aug 17, 2013 | Toshiba e-STUDIO207 Printer
We replaced the toner and it is still saying "toner life end replace toner cartridge." and we can't get it to print or fax or copy
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 23, 2009 | Brother MFC 7840W Printer
How to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Sharp AL 1631 Copier Logo
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
