Question about GE Cooktops
After I spilled milk on the burner its not
After I spilled milk on the burner its not turning on (working).
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
One burner sparks but no gas come out.
clean the burner . probably has had something spilled on it .
Mar 13, 2015 | Thermador Cooktops
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
Removing a burned milk/sugar solution from a Jenn-Air cooktop.
try a razor blade.i use them alot when i am doing service.
Dec 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Burner does not ignite when turned on.
No, it is most likely the contact problem emerging from dirt that catches on burner (spilled, grease, oil, milk etc.). Take burner off, scrub it and clean it. Same goes for its seat which is usually made of brass. They must have metal to metal contact with no dirt in between acting as isolator.
Apr 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Lighter
Dirt. Spilled oil, grease, milk etc. act as isolators and prevent contact between burner and casing (mass). You need to take of burners, scrub them, clean them. Don't forget to also clean their seats (brass elements on which they are mounted on).
Mar 09, 2008 | AEG 23 in. Competence 34602G Gas Cooktop
Cooktops Logo
165 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
