Anonymous Posted on May 11, 2010
Will not pick up paper to copy i believe a spring is off i not to see a diagram of the parts
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on May 11, 2010
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
158284
Points
1894
Can you provide more information about the product like brand and model number . What exactly the problem you are facing and how old is the unit .
Waiting for your reply.
Hello My machine is Canon iR2016 and i have problem with Paper Jam. I have problem when I copying more then one copy and i got a problem sometimes in the first 10 copys, sometime at 20th copy... Error...
so, first, did you clean the vertical path roller? ( its a axis with two rollers beneath the paper registration sensor )
Second, when you open left cover, and paper guide plastic cover ( black ) there is also sensor flapper, that can be a quite of pain because slow reaction of spring on it. Apply wd40 on its spring and in left corner where he lays into bushing. To check flapper response, manually close the paper guide plastic, the sensor must be in middle position.
Also it can be the problem in paper pick up clutch and it needs to be cleaned or replaced.
But, also the problem can be separation claws in cassette ( metal claws that holds the paper ). From experience, the probably is sensor flapper or pick up clutch the problem.
Hope that helps!
If you need service manual or help, write on [email protected]
When making copies, auto document feeder picks up paper and rollers squeal but paper gets stuck on underside. If you lift the lid about an inch the paper will feed through. HP Model L7780
open the top cover, on the very left there is a part that can be removed (running front to back) I believe you will see a scrap of paper iunder there. remove the paper, replace the part and try again
HP2430 PRINTER TRAY 2 SAYS JAM BUT NO PAPER IS STUCK IN THEIR
look it the tray there is what we call a paper sensor or a paper flag it's a small lever that is spring loaded if there is a problem with that sensor the paper will not register as being picked up by the rollers. or the paper pick arm best way to fix would to provide the serial info and I can upload you a manual for if with detailed diagram that show how to replace this part.
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
1helpful
Paper jam
Call HP and replace unit under warranty.
11helpful
2answers
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
Jamming paper at fuser. Paper try is pulling fine. Stops at Fuser
Open the fuser and look at the exit area. There should be little scrapers (pick off fingers). These are mostly spring loaded and rest on the upper fuser roller. If the spring or pressure level is missing or detached, the scraper /finger will hang in the paper path and catch the paper. There could be 4-6 scrapers. The main scrapers needed are the 2 ends and the middle. So if a spring is missing you could take the scraper/ finger out. **** MAKE SURE AS TO NOT SCRAPE THE FUSER ROLLER AS THIS WILL LEAVE A MARK ON EVERY COPY*****
IS200E image scanner ricoh
ADF is the part where you out the papers to be picked up automatically to be copied.
Open the top and look inside there is a sensor that is either out of place, stuck or something on it. There should be a door on the adf and maybe on the bottom as well, lift it up as if making copies on the glass and look into the adf is there any foreign object there, do you see a small black lever (sensor), does it have a spring action when touched (gently)??
1helpful
I have a Brother MFC-8440. I dropped the paper tray and two small springs fell out. Now the paper stack will not pop up when the tray is pushed in and the feeder can't reach the paper..... I know these...
Here is the parts breakdown PDF: Fig.8 is the paper tray .
http://piese-imprimanta.ro/pdfs/1148_DCP_8040_8045D_8045DN.pdf
You may have to copy and paste link into your browser.
Also, I can fax you the page if needed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
k24674
ADMIN Andrew
ADMIN Andrew
