Question about Canonical Ltd. Ubuntu
I keep getting a popup telling me my acidbase package or dbconfig-common. or /usr/share/doc/acidbase. needs to be fixed?? I am new to Ubuntu and I don't have a clue what this means. I was just using the updates to try and get my OS updated with the latest updates and it crashed 2 times. because of this acidbase package?? No one will tell me what it is or what it is used for???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 27 Answers
I would go to Ubuntu software center uninstall it and use Ubuntu tweak to clean any renaming software then reinstall with all the add-ons if you already done this still uninstall and use the synaptic packge manager to install my real advise is to remove it anyway you dont need it. its a security engine, the application provides alerts from a Snort ids system
Posted on Dec 27, 2011
How can i install canon pixma ip1980 for ubuntu 10.10
1) Download and install this: http://www.ziddu.com/downloadlink/2820548/driver_iP1880.zip
You can just extract the file and double click on the .deb file.
2) Open System ? Administration ? Printing ? New Printer, to Select Connection chose Canon ip1800 series USB #1
3) in Printer driver chose: Provide PPD file
4) point that at: /usr/share/cups/model/canonip1800.ppd
5) Give the name of ip1880/ip1700/ip1980 ? Apply
6) Restart the computer
7) open the terminal and write: cd /usr/lib After that, press Enter
8) write in terminal: sudo ln -s ./libtiff.so.4.2.1 ./libtiff.so.3 press Enter
9) Now it should work
Feb 28, 2011 | Computers & Internet
Tip
Mounting Win partitions (without password) In Ubuntu Karmic
Mounting Windows partitions in Ubuntu Karmic
prompts for the administrator password by default.
It can be deactivated in easy way:
1.
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
sudo gedit /usr/share/polkit-1/actions/org.freedesktop.devicekit.disks.policy
2.
In the file, search for the line (probably 34th):
<allow_active>auth_admin_keep</allow_active>
3.
Replace the above line with the following line:
<allow_active>yes</allow_active>
4.
Save
changes and close the file.
5.
Reboot your system.
on Jan 29, 2010 | Computers & Internet
How to configure qubee wimax usb modem in Ubuntu 10.10
Hi. This is alot of info, but here goes.
1. Make your ubuntu up-to-date and install necessary packages.
Code:
# update & upgrade ubuntu
sudo aptitude update
sudo aptitude full-upgrade
# dependencies
sudo aptitude install build-essential ia32-libs linux-headers libnl-dev
# library libnl 32bit version manual installation
wget http://mirrors.kernel.org/ubuntu/poo...1.1-5_i386.deb
ar vx libnl1_1.1-5_i386.deb
tar -xzvf data.tar.gz
sudo cp ./usr/lib/libnl.so.1.1 /usr/lib32/
sudo ln -s libnl.so.1.1 /usr/lib32/libnl.so.1
ldconfig
2. Download WiMAX Network Service 1.4.0 from http://linuxwimax.org/Download
3. Extract files from archive
Code:
tar xjf WiMAX-Network-Service-1.4.0.tar.bz2
cd WiMAX-Network-Service-1.4.0/
4. Build & Install
Code:
# configure
CFLAGS=-m32 ./configure --sysconfdir=/etc --localstatedir=/var --mandir=/usr/share/man prefix=/usr/local --with-i2400m=/usr/src/linux-headers-`uname -r` --build=i386
# do kung fu :)
for i in `rgrep CFLAGS\ = . ' grep -i makefile ' grep O2 ' sed -r "s/([^:]*):.*/\1/g"`; do sed -i "s/CFLAGS = -O2/CFLAGS = -O2 -m32/g" $i; done
# build
make all
# install
sudo make install
boy i hate this post when it changes things to what it thinks it should be,
try this one sir
sudo cd ./usr/lib/libnl.so.1.1 /usr/lib32/
cd is for change directory
thanks for not getting upset during this, and good luck.
I truly hope that I covered everything in it, I think I did though.
Feb 13, 2011 | Computers & Internet
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
May 26, 2010 | Computers & Internet
Trying to play DVD so at terminal window am typing sudo /usr/share/doc/libdvdread3/install-css.sh the response is "command not found" ( I am working my way through Keir Thomas's book "Beginning Ubuntu...
Well I don't know whether your objective is to study the commands or just to play DVD. If the objective is to play DVD, VLC player or Mplayer or any number of other players can be used. The install directly from software selection use package manager. If the objective is to study, I think debhelper and fakeroot is essential.
sudo apt-get install build-essential debhelper fakeroot
and try. To be honest, I use Ubuntu but I am not a great expert in Terminal. May be a better idea to play DVD is to add medibuntu repository also in the software source. Good luck
Jan 09, 2010 | Computers & Internet
Installation samsung 4300 printer in ubuntu 8.10LTX
did you checked port settings on linux control panel and printer settings ?
Mar 08, 2009 | Samsung SCX-4300 Monochrome Laser...
Mac address
Look here:
http://www.usr.com/support/doc-popup-template.asp?url=5461a/5461a-files/clonemac/clone-mac.htm&loc=unst
If not, here is the support page:
http://www.usr.com/support/product-template.asp?prod=5461
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Ubuntu Troubleshooting
One of the most common issues people have after getting their codecs installed into Ubuntu, is the sad discovery that Ubuntu won’t play Avi files from inside of your Firefox browser. Well, there is a fairly simple fix for this - lose GStreamer and switch to Xine.
You do this from Synaptic located from System, Administration in Ubuntu. In the search box for the application, just do a query for totem-xine. Once it comes up, select (double click) and then allow the uninstallation of totem-gstreamer. It’s simple!
Aug 05, 2008 | Canonical Ltd. Ubuntu
Networking with windows
Hello there.
Nice to see more people using Linux and Ubuntu. For information on how to share your Ubuntu folder to linux, over file sharing click here
You basically only need to right click the folder you want to share, in Ubuntu, then enable sharing and when prompted to install services, tick the box called 'Install Windows network support'
Hope this helps.
ps: if you haven't seen the Ubuntu community documentation, click here
Apr 13, 2008 | Computers & Internet
Canonical Ltd. Ubuntu Logo
63 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
k24674
Dennis Gutowski
Dennis Gutowski
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
