Question about Whirlpool Dryers
Whirlpool dryer model #le86200pq1...does not heat up anymore so does not dry clothers. Cannot seem to find manual. Any downloads available for this model.
  • Whirlpool Master
  • 8,220 Answers
Old School Dryer Nice one. Whirlpool dryer model #le86200pq1...does not heat - 9b580b7.jpgprobably the element. Take the dust cover off the back1bc83b1.jpg and check the compents. It ain't always the element if you have blockage then them fuses bloWhirlpool dryer model #le86200pq1...does not heat - 3aca83a.jpg blows when the vent is clogged3aca83a.jpgCheck these area also24a7597.jpgYour OLD SCHOOL SERVICE MANUAL MATE!
Posted on May 11, 2010
Dryer will not dry the clothers
I would think thru the back
Mar 09, 2013 | Dryers
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
I have a Whirlpool dryer model LER4634JQ0. It now takes many cycles to dry the clothers. I checked the vent coming out, it is not clogged. I can reach in and feel a little fan motor, which I assume...
your vent line from the wall to the outside of the house can be clogged
or your you high heat coil is burned out and just the low heat coil is working, when you switch to high, both coils work. or you have a one coil system and the heat selector maybe defective
Please rate/vote the response Thanks
Dec 20, 2010 | Whirlpool Dryers
Dryer not heating up
Check your heating element!!!
Jun 28, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Whirlpool LGR4634JQ2 gas dryer, I have checked all the venting from the dryer and nothing is blocked. However, the dryer still does not dry my clother properly. Sometime the heat comes on and...
This free video will walk you thru troubleshooting the problem. Could be a few different things Igniter,coils,heat sensor,thermal fuse, thermostat
Feb 26, 2010 | Whirlpool LGR4634J Gas Dryer
Dryer not drying clothers
Check that your unit has proper voltage to the back of the dryer. The next thing I would check as you said would be the heating element and over temp and safety limit devices. These are not resettable and must be replaced.
Feb 13, 2010 | Whirlpool LEQ9858P Electric Dryer
Whirlpool wed8300sw0 runs thru the cycle and will then add time(Clothers are dry) to it but not all the time. moisture senor is working. in the motor and heat test i dont get any of the codes shown on hte...
I ran into this last week. Customer said that when on auto dry. Unit would run for a long time. When he checked the unit, the display showed 1:40 left but he opened and checked. Clothes were bone dry. His last power bill was $400.00 when normal was $210.00. I called factory and ran the internal codes. The first thing that came up was F1. Meaning bad main board. I'm waiting on part so I can install on customers unit.
Please rate solution.
Aug 27, 2009 | Whirlpool WED8300S Dryer
My dryer is not blowing hot air anymore
most likely the thermal fuse 279769 or the heating element 279838 if this is a newer dryer...whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Dryers
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Dryers Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
