Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Low pressure upper and mid level not putting out spray low level barely spinning
    President:
  • 949 Answers
This is most often caused by debris in the sump area of the pump for this model. Here are some instructions on how to clean it out. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 11, 2010
The upper spray arm on my Frigidaire dishwasher doesn't spin during washing
low water pressure or quantity, check spray arm rotation by hand (manual) no obstraction?
Oct 09, 2013 | Dishwashers
Dishes on upper rack are not being cleaned. Seems like upper sprayer is not working properly.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
Jan 01, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
UPPER LEVEL SPRAY DOES NOT SPIN - UPPER LEVEL NOT
plugged spray arm holes, pump intake partially blocked, too little water getting in tub cuz screen in fill valve has debri
Dec 21, 2009 | KitchenAid KUDC25CH Dishwasher
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher not cleaning properly
a low water level will certainly cause your problem. the water valve may indeed be bad. first, check the water level mid-cycle. let the machine really get going. then crack the door. let the water stop flying around. and open it up to check the water level inside the machine. your heating element should be partially or even completely submerged.
if the level is high enough, your water valve is most likely fine. and i have no idea what to do.
if the level is low, the valve may need replaced. another common reason for this is low water pressure in the entire house. a new valve will not help you (or me). if you are handy, you can pull the 'restrictor plate' out of the inlet valve. it is under the screen filter where the water line hooks up. it looks like a washer with a small hole in the middle for the water to flow through. it should pop right out for you. this will allow the water to flow in more freely. don't forget to put the screen filter back in.
also, that screen being clogged may cause your problem. good luck
Nov 07, 2009 | Dishwashers
The dishwasher doesn't seem to have nearly enough water in it. The upper sprayer arm doesn't seem to be spinning when running (I open the door and look really quick) and the lower one looks like it barely...
I would lift the drain pipe higher. approx. 1/2 the height of the dishwasher . also rechack incomming water supply. Make sure no blockages and the like. Try again.
Sep 21, 2009 | Bosch Dishwashers
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Not fnishing wash cycle!
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
Jan 04, 2008 | Washing Machines
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
241 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
