Question about HP OfficeJet 4215 All-In-One InkJet Printer
Printer prompting that it is not detecting the black ink cartridge .says it cannot read the cartridge, but it is the same one that has been in there , along with the tricolor cartridge. printer not resetting
  • 235 Answers
If the ink cartridge is the same ink cartridge since you have pruchased it, it may have run out of ink or the ink cartridge is broken, that is the only two posible reason thats why you always recieve these messages, check can check the ink capacity through the hp utility tools, if the cartridge has run out of ink or it is broken you will need an ink cartridge replacement
Posted on May 11, 2010
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
Black ink cartridge is full, when printing no black showing
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Or
When you insert a refilled ink cartridge into your Pixma MP500 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
Feb 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have just replaced the black cartridge of my Brother 685CW printer and fax. Prompt says 'No cartridge". tried all the solutions above to no avail. I need to use printer urgently. Please help. Moh.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 27, 2010 | Brother MFC-685cw InkJet Printer
My HP Deskjet F2480 is all set up but won't print. I don't have any ink in the colour cartridge. Could this be the problem?
If there's no ink in the color cartridge and the printer detects it and prompts you to replace the cartridge, you'll never be able to print unless you replace it. Sometimes only with the Color cartridge, we can make print outs, while the black cartridge is still installed (but the printer shouldn't detect it, if it does detect, there's no way to do this either) but only with black cartridge filled and no color is not possible.
It should work fine after it's replaced, if the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Sep 07, 2010 | HP DeskJet F380 All-In-One Printer
Black ink cartridge
you should be able to disable black ink printing by going to the printer preferences selection through your Windows OS printer & faxes function.
Alternatively, if you have loaded the printer monitoring CD that came with your printer then the ink status function should prompt you to disable the black cartridge if it detected it has run out.
May 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Epson 4800 won't initialize after changing black cartridge
Did you change from matte black to photo black? Or vice versa? If so you have to use the ink conversion kit that came with your printer and draw out the old ink and install the new black in cartridge. Try page 113 in your owners manual. I am having a similar problem but with the light cyan and it says "set ink cartridge".
Feb 03, 2009 | Epson Stylus Pro 4800 InkJet Printer
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
Nov 12, 2008 | HP PhotoSmart C4280 Laser Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
172 people viewed this question
Seeker5211
Seeker5211
