Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Put oil in transmission,, it leaks out by the fly wheel adjust hole also on lower pan with the 4 bolts, whats up . I loose power stearing and loader, big leak..
  • 333 Answers
It sounds like the front seal on the transmission. The seal that the shaft comes out of going to the motor. The pan that you say with the hole sounds like the cover to the flywheel?
Posted on May 11, 2010
I have to lower the front crossmember to remove the oil pan. Is there any precautions I should know about? It is on 2004 jeep liberty 4x4
no engine stated, they even have diesel. or 3.7L GAS.
I toss my first coil, land on 3.7L V6.
great question, like the very first ever.
most just do it and get in trouble. vast posts in this.
but whats up, what is wrong, what part failed.?
this is best to know, so we can send you the official chapter on this from jeep.
sure use jackstands, never jacks only and never bricks .
04,KJ jeep 4wd pan off.
in chapter 9 ,under diagnostics, and pan leaks. that?
it says read
Refer to 9 -
ENGINE/LUBRICATION/OIL PAN -
REMOVAL). page 1555 (3.7L)
and i quote:
REMOVAL
1. Disconnect and isolate negative battery cable.
2. Install engine support fixture.
3. Raise and support vehicle.
4. Remove front wheel assemblies.
5. Remove skid plate (if equipped). (Refer to 13 -
FRAME & BUMPERS/FRAME/FRONT SKID
PLATE - REMOVAL)
6. Drain engine oil.
7. Mark adjustment cam position of front lower control
arm bolts.
8. Remove front lower control arm bolts. (Refer to 2 -
SUSPENSION/FRONT/LOWER CONTROL ARM -
REMOVAL)
9. Disconnect LH tie rod. (Refer to 19 - STEERING/
LINKAGE/TIE ROD END - REMOVAL)
10. Disconnect LH lower ball joint (Refer to 2 - SUSPENSION/
FRONT/LOWER BALL JOINT -
REMOVAL)
11. Disconnect LH strut clevis (Refer to 2 - SUSPENSION/
FRONT/CLEVIS BRACKET - REMOVAL)
12. Remove LH front axle (Refer to 3 - DIFFERENTIAL
& DRIVELINE/HALF SHAFT - REMOVAL)
13. Remove front axle brace bolts.
14. Remove front prop shaft. (Refer to 3 - DIFFERENTIAL
& DRIVELINE/PROPELLER SHAFT/
PROPELLER SHAFT - REMOVAL)
15. Drain front axle.
16. Using a transmission jack, support front axle.
17. Remove axle bracket bolts. (Refer to 3 - DIFFERENTIAL & DRIVELINE/FRONT AXLE - REMOVAL)
18. With RH axle still in place, remove front differential.
19. Remove transmission oil cooler line bracket.
20. Remove engine to transmission stiffening bracket.
21. Position Special Tool 8534 on fender lip and align the slots in the brackets with the fender mounting holes.
22. Secure brackets to the fender using four M6 X 1.0 X 25 MM flanged cap screws.
23. Tighten the thumbscrews to secure the sleeves to the support tube.
24. Secure the support tube in an upright position.
25. Assemble the flat washer, thrust bearing, hook and T handle.
26. Using the M10 X 1.75 mm flanged nut supplied with the support fixture, secure the chain to the front engine
lifting stud.
27. Loosen engine mounts.
28. Remove oil pan bolts.
29. Seperate oil pan (1) from engine.
30. Move oil pan to one side, remove oils sump bolt and windage tray bolts,
NOTE: Do not pry on oil pan or oil pan gasket. Gasket is integral to engine windage tray and does not come
out with oil pan.
end quote, (off)
Nov 30, 2016 | 2004 Jeep Liberty
I have fluid leaking from the bottom of the transmission. Could it be a seal, gasket or do I have to replace the transmission?
What vehicle?
What leaks?
There is no reason to replace anything but the
pan gasket or side case drive axle seals, if you have a front
wheel drive transaxle
You have to get under these vehicles & provide
some info.
They should call this site the Guessing Game Place
Aug 28, 2013 | Cars & Trucks
My 2005 Chevy Cavalier is severely leaking oil from a bolthole on the bottom of the oil pan. It is not the oil plug hole and there are a few holes like it without bolts in them but there is only one...
SOUND LIKE HOLE IN OIL PAN IF THE OIL PAN DRAIN PLUG NOT LOOSE OR MISSING AND THE UPPER PAN BOLTS HOLES NOT MISSING A BOLT CAUSE LEAKING.MORE LIKELY YOU HAVE HOLE IN THE OIL PAN.
Jul 21, 2011 | 2005 Chevrolet Cavalier
Hoow to set up the timing belt
What do you mean by drive belt. If your talking about the serpentine belt, it should have an auto tensioner. Same goes for the timing belt. There is no adjustment. If the belt is loose then it needs to be replaced.
Replacing timing belt,Sienna 1998:
1.Disconnect battery (-) cable and plastic wiper washer cowl assembly
2.Remove spark plugs and put all wirings,cables out of the way
3.Drain coolant (cold) and remove upper hose
4.remove front right tire and wheel plastic fender apron
5.jack up engine under oil pan with rubber,towel or wood slightly
6.remove right engine support rod and its bracket
7.remove all drive belts.Examine condition;Label if re-using
8.remove plastic upper timing belt cover & gasket
9.remove crankshaft pulley bolt-use the ff. methods: a.air impact wrench or Toyota Special service tool-best b.chain wrench on pulley then breaker bar/socket on bolt-good c.open fly wheel cover,jam screwdriver on gear teeth then unbolt-tough d.breaker bar/socket on bolt, jam bar tip on floor, lower car then "start" engine -smart
10.remove pulley by hand or use carefully 2 prybars then remove plastic lower T.B.coverand gasket
11.reinstall bolt and turn engine clockwise to align timing marks:one on each camshaft sprocket and one on the crankshaft sprocket
12.remove T.B. tensioner spring-2 bolts loosen alternately then keep upright
13.remove crankshaft sprocket guard then the sprocket, then the belt.
14.Examine belt condition for damage and correct cause of damage if any
15.remove idler T.B.pulleys & check for smooth operation/contamination/leak
16.check all oil seals, water pump leaks,etc
17.Check T.B.tensioner spring for oil leak and tension by pressing push rod against hard object-there should be no movement or leak
18.Compress push rod using vise, align rod hole with outer hole then insert small nail, pin or wire to keep it there then reinstall along with other parts removed
19.Install T.B.carefully.No twist, stretch,prying ,oil, moisture, bending
20.Handturn engine 720 deg.clockwise, feel for resistance , and then see timing marks still re-align
21.Reinstall plastic covers and gaskets,drive belts.etc in reverse order 21.
Hope this helps.
Mar 02, 2011 | 1998 Toyota Sienna
How do you replace an oil pan for 2001 mitsubishi eclipse?
Assuming you're talking about the lower oil pan...it's very simple
1. Lift at least the passenger front side of the car using a jack, jack-stand, and blocks on the rear wheels
2. Drain the oil out of the pan by removing the drain plug (just like an oil change)
3. Remove all of the bolts on the outside edge of the oil pan (should be about 11)
4. After all of the bolts have been removed the oil pan is free to come off. It might still be stuck on and a few gentle taps with a rubber mallet with knock it loose. Be aware that there is still some oil inside the pan, so this step will be pretty messy
5. Clean the surface of the engine where the oil pan was mounted against
6. Take your new oil pan and place the gasket around the rim of the pan (if not using a gasket then put liquid gasket around the rim. This is important to ensure the pan doesn't leak)
7. Place the oil pan on the engine and bolt it back on. Start by tightening on bolt, then one as close to 180 degrees across from it. Repeat until all the bolts are tightened.
8. Fill the oil pan with new oil. You may also wish to remove and replace the oil filter.
9. If you used liquid gasket, give it a few hours to set (look at contained for a recommend amount of time to wait). If you used a rubber gasket, you don't need to wait.
10. Start the engine and check for leaks. If you notice any oil leaking from around the seal then turn the engine off, go back to step 2 and then repeat from there on. If you don't see any leaks, you are good to go.
Dec 29, 2010 | 2001 Mitsubishi Eclipse
Can you walk me trhu the transmition fluid change im going to chenge the transmition fluid my self
This job requires some special tools first a swivel to get to the pan bolts and you have to remove all nuts off the oil pan on the transmission. you will need a pan to pick up 4 quarts of fluid that will come out when you loosen the oil pan, next after you hav all the nuts out use a pat scraper and a hammer and tap around the edge of the pan to get the pan loose, next once the pan is off unbolt the screen from the transmisson housing, Next drop the pan and then remove the filter remoce the filter oring and install new one from the kit you bought. clean bolts out then put the bolts in the holes and screw then in so you can install pan back on without the gasket falling off, after filter is in place and screwed on screw on the oil pan for the transmission go from right to left and front to back one bolt at a time tighten lightly till all bolts are snug. next undo the treansmisson line on the bottom of the radiator seperate the line and start the motor put it in drive with emergency brake on then put in low gear and allow 3 quarts of oil to drain out of transmission,, shut off motor and add 5 quts of ATf dexron 2 or dexron III EATIER WILL WORK . next with line still loose run three more quarts out, it will take about 12 quarts to change all trasnmisson fluid to change out all fluid also add one quart of lucas transmisson condtioner this will make the transmison shift smother and soften band and seals put the line back on the oil cooler on the radiator then start the car in park check for leaks, if you see no leaks then at idel check fluid level it should not be less than a pint low or a pint high it will cause problems. if you add to much loosen the line and let some run out then tighten and you check the fluid again if it's to the top you done. test drive after done this will take about 4 hours doing it this way good luck on your job.
Aug 17, 2010 | 2000 Ford Windstar
Need to change oil pan
e
Cavalier, Sunfire 2001-2005
Oil Pan - Removal & Installation
2.2L (VIN 4) Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Right front wheel Right inner fender splash shield Starter motor and bracket Engine mount strut bracket Oil pan
To install:
Fig. Exploded view of the oil pan mounting and related components-2.2L (VIN 4) engine
  1. Place a 2mm bead of RTV sealer to the oil pan sealing surface except at the rear seal mounting surface. Using a new oil pan rear seal, apply a thin coat of RTV sealer on the end down to the ears.
  2. Install or connect the following:
    Oil pan with a new gasket. Torque the nuts and bolts to 89 inch lbs. (10 Nm). Engine mount strut bracket. Torque the bolts to 49 ft. lbs. (66 Nm). Starter motor and bracket. Torque the bolts to 37 ft. lbs. (50 Nm). Right fender splash shield Right front wheel. Torque the nuts to 100 ft. lbs. (140 Nm). Negative battery cable
  3. Refill the crankcase.
  4. Start the vehicle and verify no leaks.
2.2L (VIN F) Engine
    Engine mount strut bracket Drive belt Lower then upper AC compressor bolts Oil pan bolts Oil pan
    Fig. Remove/Install the oil pan bolts in this sequence-2.2L (VIN F) engine
To install:
  1. Apply a 2 mm bead of RTV sealant around the perimeter of the oil pan and the oil suction port opening. Do not over apply the RTV. More than a 2 mm bead is not required.
    Oil pan and tighten the bolts to 18 ft. lbs. (25 Nm) AC compressor bolts Engine mount bracket Drive belt
2.4L Engine
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    Negative battery cable Flywheel/converter cover Right wheel Right wheel well splash shield Accessory drive belt Air conditioning compressor lower bolts Transmission-to-engine brace Engine mount strut bracket Radiator outlet pipe bolts Radiator outlet pipe from the oil pan Oil pan to the flywheel cover bolt and nut Flywheel cover stud for clearance Radiator outlet pipe from the lower radiator hose and oil pan Oil level sensor connector Oil pan
To install:
  1. Inspect the oil pan gasket; it is reusable if not damaged.
    Oil pan with the gasket. Torque the M8 bolts to 18 ft. lbs. (24 Nm) and the M6 bolts to 106 inch lbs. (12 Nm).
    Fig. Oil pan fastener torque specifications-2.4L engine
    Oil pan to the transmission nut Oil level sensor connector Radiator outlet pipe to the lower radiator hose and oil pan Exhaust manifold brace Radiator outlet pipe. Torque the bolts to 124 inch lbs. (14 Nm). Engine mount strut bracket. Torque the bolts to 55 ft. lbs. (75 Nm). Transmission to the engine brace Air conditioning compressor lower bolts. Torque the bolts to 37 ft. lbs. (50 Nm). Accessory drive belt Right splash shield Right front wheel Flywheel/converter cover Negative battery cable
  4. Refill the cooling system.
  5. Start the vehicle and verify no leaks.
Hope helped (remember rated this help). Good luck.
Oct 22, 2009 | 2001 Chevrolet Cavalier
How do I change the tranny fluid in my 1998 cadillac catera
Fluid - A/T: Service and Repair
Transmission Fluid and Oil Filter Changing
REMOVAL PROCEDURE
1. Raise and suitably support the vehicle. Refer to Vehicle Lift Points.
2. Place drain pan under pan
3. Remove oil pan bolts from front and sides only.
4. Loosen the rear oil pan bolts approximately four turns.
5. Lightly tap the oil pan with a rubber mallet or pry to drain the fluid from main case.
6. Remove the oil pan bolts from rear oil pan and gasket.
7. Remove front oil pan bolts leaving one corner bolt in loosely.
8. Lightly tap oil pan with rubber mallet or pry to drain fluid.
9. Remove the following remaining components:
^ The front oil pan bolts
^ The oil pan
^ The gasket
10. Remove the oil filter bolts and filter.
11. Clean the following components:
^ The transmission case
^ The front adapter case
^ The oil pan gasket surfaces with solvent
^ Air dry
^ All traces of gasket material must be removed
INSTALLATION PROCEDURE
1. Install the gasket.
2. Install the oil filter.
3. Install the bolts.
^ Tighten the transmission oil filter bolts to 20 Nm (15 ft. lbs.).
NOTICE: Refer to Fastener Notice in Service Precautions.
4. Install the front oil pan.
5. Install the front oil pan gasket
6. Install the front oil pan bolts
^ Tighten the front oil pan bolts to 11 Nm (96 inch lbs.).
7. Install the following components:
^ Install the pan
^ Install the gasket
^ Install the bolts
^ Tighten the oil pan bolts to 11 Nm (96 inch lbs.).
8. Refill the transmission with DEXRON III through oil pan fill plug on the side of the (main case) oil pan. Fill the transmission to lower edge of oil
pan fill. Fill plug opening using and oil suction gun.
^ Tighten the oil pan fill plug to 45 Nm (33 ft. lbs.).
9. Lower the vehicle.
10. Check the transmission fluid level. Refer to Transmission Fluid Checking Procedure.
Sep 13, 2009 | 1998 Cadillac Catera
Put in transmission in feburary.
you will still need add the proper type fluid to proper fill level, get under the truck, clean up transmission so you can visually monitor where the leak is coming from. Chock the wheels, emergency brake set, start and idle vehicle check for leaks. If trans is leaking it will probably be a front seal (oil will drip from small hole in the bottom of bell housing), pan gasket, loose cooling line to radiator, or rear tail shaft leak ( where drive shaft enters the trans.) Don't forget to check the lines for pin holes and the radiator for leaks.
Jul 04, 2009 | 1996 Ford Explorer
2003 oil pan removal
4.0L Engine To Remove:
  1. Disconnect negative battery cable.
  2. Lift the vehicle.
  3. Drain the engine oil.
    • Exhaust pipe from exhaust manifold.
    • Exhaust hanger at the catalytic converter and lower the pipe.
    • Starter motor.
    • Flywheel/torque converter housing access cover.
    • Oil level sensor (if equipped).
  5. Place a pole jack under vibration dampener with a piece of wood between dampener and jack.
  6. Remove or disconnect the following:
    • Engine mount through bolts and raise engine for clearance to remove pan.
    • Transmission cooler lines (if equipped).
    • Oxygen sensor harness from oil pan mounting studs.
    • Oil pan bolts and studs.
    • Oil pan and gasket.
To Install:
  1. Clean the gasket mating surfaces.
  2. Apply Mopar® Silicone Adhesive Sealant or equivalent onto the cylinder block in four location as shown.
  1. Attach the pan gasket to the oil pan with Hi-tack or equivalent (2003-2005 vheicles).
  2. Use 1 ½ x ¼ inch bolts to fabricate alignment dowels. Cut off the head of the bolts and cut a slot into the top of the dowels (2006 vehicles).
  1. Install two dowels into the timing case cover (2006 vehicles).
  2. Install two dowels into the cylinder block (2006 vehicles).
  3. Place the gasket over the dowels and onto the cylinder block and timing case cover (2006 vehicles).
  4. Position the oil pan.
  5. Install the 1/4 inch oil pan bolts. Tighten to 84 in-lb (9.5 Nm).
  6. Install the 5/16 inch oil pan bolts. Tighten to 132 in-lb (15 Nm).
  7. Remove the dowels.
  8. Install the remaining 1/4 inch oil pan bolts. Tighten to 84 in-lb (9.5 Nm) (2006 vehicles).
  9. Lower the engine onto the engine mounts.
  10. Install the through bolts and tighten the nuts.
  11. Remove jack stand and remove the piece of wood.
  12. Install the flywheel and torque converter access cover.
  13. Install starter motor.
  14. Connect the exhaust pipe to the hanger and to exhaust manifold.
  15. Install the transmission oil cooling lines (if equipped).
  16. Install the oxygen sensor wiring supports to the oil pan mounting studs.
  17. Install the drain plug into the oil pan. Tighten to 25 ft-lb (34 Nm).
  18. Lower the vehicle.
  19. Connect negative battery cable.
  20. Fill the oil pan with oil. WARNING
    Use extreme caution when the engine is operating. Do not stand in a direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing.
  21. Start the engine and inspect for leaks.
Jun 06, 2009 | 2003 Jeep Wrangler
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
236 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
