Question about HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 stuck cartridge
Paper feeds to the point where printer would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge appears to be stuck in far right area of cartridge track. Nothing appears to be preventing cartridge movement, however it appears to be locked into place.. Suggestions?
Bill Ames
  • 2 more comments
  • Dante2000 Jun 05, 2008
    I have exactly the same problem. New drivers did not solved either.
    After reading some of the tricks to get the the damm thing open
    I will try to open and see what is inside. Will report back tomorrow
    Dante
  • S Shelton
    S Shelton Aug 08, 2008
    Same as two above and solutions tries. Printer picks up paper, seems like it will print, grinding noise, then red light. I did get a test page and sample page to print and 1 document I put in, then, it started all over again. Even when it printed there was a grinding noise
  • kgarland1 Oct 09, 2008
    My problem is similar- if not exactly the same... try this one out.
    I had just finished printing some documents and attempted one more when the printing process stopped just where it would normally begin. Pop up said it was a paper jam. I removed the back door and pulled the paper out no problem- it of course attempted the print again with the same problem. The paper doesn't appear to be jammed at all, but it stops at the same place every time it pulls the paper into it. If everyone is having this problem is it a faulty printer or something we all happened to do wrong?
  • Anonymous Nov 18, 2008
    printer acts like it will print pulls the paper through to far and carriage gets stuck all its says is it is a paper jam you take the paper out and the carriage is all of a sudden unstuck can anyone help me
I'm no expert but drivers don't make gears break. All of you have the same problem as me and it's a broken tab on one of the plastic arms that in gauges with the gears.
Posted on Oct 03, 2008
Not a solution, my paper feeds past the point where printerHP Photosmart 7450 stuck cartridge - 5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Posted on Apr 03, 2008
    Genius:
  • 3,587 Answers
Hmmm...well..that's a 'reset' position for that carriage..means that the print commands are corrupted.
suggest you remove the old s/w
go here for new fresh set of drivers(don't use CD version)
re install
try again with test page first.
Posted on Mar 28, 2008
SOURCE:
My hp Photosmart 7450 printer was working, then in the middle of printing it stopped and there is an error message on my computer, the green light is blinking on printer but won't print
First things first... try connecting your printer to another pc or laptop and try printing... make sure spooling is on in the driver and there are no other programs running...
if issue reappears then
It sounds like your printer cartridges are the issue
I would try reinstalling them...
if that does not work then
I would try cleaning your printer cartridge...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges
hp photosmart 7450 ink cartridges
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | HP Photosmart 7450 InkJet Printer
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Prints "fast draft" only
hi to all ... my printer did not work good when I give it order to print the first paper let it with out pint but it print after that a bout 5 sheet than stop .notis I order one copy.....what should I do
Dec 18, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 immediately either jams or light turns red.
This link will give you information on clearing random jams that can happen with your model. Just click both links and follow the instructions listed there.
Also, this link will give you information and steps to take regarding the lights on your product.
Hope this helps. Please remember to rate this information.
Thanks
Nov 26, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450
Most printers have a photosensor on the head assembly and the assembly (as it moves back and forth) rides on a strip of plastic that is dark with clear spots. That is how the cpu in the printer knows where (left to right) the head asm is located. So, If that strip is broken, or dirty or if the sensor is dirty this can happen. The sensor could also be defective. Try using some canned air to GENTLY blow away any paper residue in that area and then reset the power to the printer. If that doesn't help, then the printer needs serviced.
Hope that helps...
Geno
Apr 04, 2008 | HP Photosmart 7450 InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
501 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
