Question about Jandy Laars Lt 400,000 Btu Heater
I have a Jandy LITE2 LG325. Only two years old.
I have a Jandy LITE2 LG325. Only two years old. Pilot lights but can't fire burners. Any suggestions?
  • 333 Answers
Does the pilot light stay light? Or light then go back out? If it is doing that then it is the thermocoupler. looks like a wire that is in the flame of the pilot light. Other than the sparker. That is what dectects that there is fire in the pilot light before it starts the gas. Safety thing. So if that isnt detecting fire, then it will never let the gasvalve open up, Try taking some steel wool or real fine sandpaper and clean up that sensor. The wire. It builds up a thin film on it from gas burning.
Posted on May 11, 2010
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
I just replaced the pilot generator on a jandy lite2 and the pilot stays on but the burner will not light. I am getting over 500 millivolts at the gas valve. Any ideas? Thanks
500 millivolts is good to fired that heater, the minimum is 250. disconnect the wires connect to the gas valve be very carefulland see if the pilot stay on, if stay on get a piece the solid copper wire and jump the gas valve where the wires from the safety switches were connected and see if the heater fired. but before that check everi wire and safety switches for resistem ,also you water pressure switch,but also for any loose connection .
Jun 05, 2013 | Pool & Spa
I have been working to get my heater started since Spring. My pool contractor has been out and cleaned, fixed any issues but now says if I have too high a pressure from my DE filter, the heater will not...
the contractor is correct about having to high pressure in DE filter. it will prevent pressure switch from closing, therefor burners wont fire. However, the pilot issue is a diff problem. you most likely need a new pilot generator
Jul 04, 2011 | Jandy Laars Lite2 Lj 250,000 Btu Heater
-Pilot Won't Light- My Lite2 LG is 2 years old, but never used. I just hooked up the gas with 3/4" pipe and pressure/flow is good (I don't have a manometer tho). The pilot flame won't light (igniter is...
Open up the union in the gas line and bleed all the air out. Once done the pilot should light in a short amount of time. If it still will not light, remove the pilot and inspect it for spider nests in the head or regulating cap.
John
Sep 21, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Pool heater will not come on
sounds like a plugged pilot - pull it out and clean it, should fire right up
Sep 01, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Pilot light is lit, burner will not come on
The thermocouple must be in the flame of the pilot and producing a signal to the gas valve. Also check thermostat
Jul 18, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
I have a Jandy Lite 2 Heater model LG250N
You don't use heater very often. make sure you clean gas nipplets from web, wasp nests try that?
Jun 12, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Jandy Laars Lt 400,000 Btu Heater Logo
203 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
