Question about Whirlpool Calypso GVW9959K Top Load Washer
FL code how do i fix it - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!%$!
Posted on Sep 18, 2010
My machine is flashing with the code FL, what does tha mean and how can I fix it?
The "FL" error code is indicating an overfill condition which is most likely due to the unit not draining properly or the pressure switch did not reset after the water was pumped out.
Mar 21, 2011 | Washing Machines
How do I fix the FL ERROR CODE?
FL = Flood condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
hope this helps
Aug 11, 2010 | Washing Machines
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer is blinking the code fl.
Greg, best thing is to take the drain pump motor out. get to the impeller and check for any obstructions. Normally the filter is on the frame of the drain pump assembly.
Jun 16, 2010 | Kenmore 23822 Top Load Washer
My kenmore elite reads fl and stops working,
Flood Condition:
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Can not clear the FL code. Want to fix machine don't know where to start. Diagrams would be helpful.
This is a flood condition.
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
If it continues, simply replace the over fill switch.
May 28, 2009 | Whirlpool Washing Machines
I have a whrilpool calypso washer flashing the fl code
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
We have an FL error - all the manual says is to press stop/cancel...it's not working. How do we fix this?
Flood Condition:
Jun 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer problem
Washer flashing FL. Still has some water in tub. Won't completely drain. Washing not functioning at all.
Jeff
Jun 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
