Question about Garden
Master cut edger 2.0 manuals wont start
I bought the edger from a friend. He told me that it hasn't been used for quite some time. I replaced the fuel line, oil and spark plug, I took off the aircleaner cover checked the the throttle and choke to see if gas was visible in the carb. there was gas so I attempted the pull start first 2 times failed , at the 3rd pull, it started, it stayed on for a couple of seconds and died. I can't get it started now . what did I do wrong
  • 333 Answers
Not positive but it sounds like it ran out of gas. Maybee a leak in one of the hoses? Or a piece of trash worked its way into the needlevalve or internal screen
Posted on May 11, 2010
Why does it try to start by itself?
starter solenoid is bad replace starter. Check fuel pump circuit and fuse to ensure it's getting current to the fuel pump relay.
Feb 03, 2016 | 2006 Kia Sorento 3.5
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Over past few weeks my 01 gmc jimmy has been starting after 3-4 times of trying. Sat morning it quit starting and hasn't started since.have replaced the icm, fuel pressure regulator, coil
check for a spark and the fuel pressure on the fuel rail here you will find a tyre valve with a plastic cover ,you can use one of them old fashioned tyre pressure things that push out with the air pressure but it will work on the fuel as well ,should be 55lbs
Apr 16, 2012 | 2001 GMC Jimmy
My friend bought a Honda NSR 125 Supersport on a J plate from Ebay. He was going to use it for a project, but instead he gave it to me and its now been standing for 2 years. I took off the fuel tank to be...
since its *** just put some gas init and make sure it flows to carb-put on the choke and start kikin--if doesnt take at all then chec for proper spark--gas in the float bowl or a compression test--be sure theres oil in engine--inspect tires and breaks and lites--buy a maintenance manual--not an owners
Sep 21, 2011 | Honda NSR 125 Motorcycles
Golf gti 2.0 8v keeps cutting out now it wont start
Just found your problem while looking for solutions to my own. My 2.0 8v 3door 97 golf gti can also cut out after driving for two or three minutes. Works fine one day then dies instantly 5 times the next...not a safe thing to happen pulling out of a junction!! Have researched problem and been told that it's probably fixable for £12-15. The "Hall Sender Relay" which is the fancy name for the ecu's power supply relay can go on the blink and cut power at any time causing instant shutdown...just like turning off the ignition key. Part number is 165906381 and available from a local vw dealer usually overnight. I'm fitting mine tomorrow 4/4/09...fingers crossed! Hope this helps others...worth a try for the cost involved.
Allymac
Jul 14, 2009 | 1996 Volkswagen Jetta
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
My car wont start and it gots fuel and spark?
Double check the timing belt. It might be on but stripped. Have some one crank it over and look in the oil fill cap to see if the rocker arms are moving when you crank it.
Apr 12, 2009 | Ford Escort Cars & Trucks
Cordless phone conflict with wireless home computer router
It looks like it's been solved by purchasing a new 1.8GHz phone- the new one seems to be having no problems. The retailer shop man said they often hear of this type of problem and recommend the 1.8GHZ models -- wish they'd told us that before we bought the previous one!!!
Jan 02, 2009 | Uniden Cordless Phone
Garden Logo
176 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
