Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How do i download data onto my scandisk - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
    Genius:
  • 1,098 Answers
Hello chaqhat4!
Just connect to the flash drive onto the USB port of your computer. Go to MY COMPUTER, you should see your flash drive there as REMOVABLE DISK.
To transfer your files or data onto the flash drive, make sure that your MY COMPUTER window is open. Access the file folder (wherever you saved it, ex MY DOCUMENTS), highlight it and drag it onto the REMOVABLE DISK ICON in the MY COMPUTER window. It will transfer the data or files from your pc to the usb flash drive.
Hope this helps!
Posted on May 11, 2010
  • 1,472 Answers
Chaqhat4
You would access it from My Computer like your normal harddrive. Note if the removable drive is showing up in My Computer then this is a sign that another device is already been assigned to the drive your USB drive wants by default. The links below will help you assign a drive letter to the USB drive.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
How do I refresh my micro scan disk?
With the scandisk inserted in your computer, locate the drive where you inserted and the file folder with the data you want to erase and delete or empty the file folder. If you do not have an available drive to place the scandisk, connect the media device with the scandisk included and locate the data via drive/file folder. You can locate the drive/file folder by clicking start>computer>drivelocation>scandisk folder.
Apr 19, 2013 | SanDisk 2GB microSD Memory Card
I have a packard bell external hard disk 2,5 500gb. a few days ago i noticed that i was no longer able to view or cancel certain data from it so i formatted the hard disk . after formatting i then sent the...
You can use stlerphonex for recover any data even after formatting the hdd . Please download below the link.
http://www.freedownloadscenter.com/Utilities/Disk_Analysis_Utilities/Stellar_Phoenix__Data_Recovery_Software.html
No need to install just copy and paste and dubble click it can be run.
I always use it .
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 19, 2011 | Computers & Internet
Scandisk micro syncs all 'My documents' with comp plugged into
open scandisk settings and disable that feature.
or else you can simply delete scandisk software and use your pen drive.
Sep 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sir my scandisk pen drive can not open on any pc
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Disk crash data recovery
its time for a data recovery operation. you'll want to find someone nearby, as this is a 50/50 effort at best.
got backup?
Feb 17, 2008 | Computers & Internet
Scandisk 2.0 gb
You can manually transfer the files from your Limewire folder to the device thru My Computer. My Computer>Device Name(e250)>Music Folder. Or, you can use windows media player to transfer. How to videos are here; http://www.sandisk.com/Retail/Default.aspx?CatID=1468 Best of Luck.
Sep 30, 2007 | SanDisk Sansa e200 MP3 Player
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
131 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
