Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Back fireing 22hp v-twin briggs, run but back fires all the time it's running. is this a valve or damaged flywheel key problem?
  • 333 Answers
I dont think that it would keep running if it was a damaged flywheel key? Seems like eventually it would go on and slip too much. But a leaking valve sounds like the most logical answer. Take the spark plugs out and stick your finger over each cylinder and turn it over. see if one of em has more compression than the other. If one is take the valve cover off that one. and see if you can see a week spring or something.
Posted on May 11, 2010
Only firing one cylinder, replaced both plugs and one coil? What else could be causing this?
Justin, Did you replace the right coil, are the leads good,
Are both the triggering magnets still in the fly wheel,are they clean? Touch any piece of metal to both of them and make sure they are equal strength or close to it. If one magnet weak replace.
Twin cylinder briggs and stratton not firing on 1 side
22hp twin Briggs running on one cylinder at idle MyTractorForum com The...
Lawn tractor 1 cylinder not firing General Discussion Forum In Depth...
Briggs 422707 Firing one cylinder
Feb 09, 2016 | Garden
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard backfires through carb
If you say the valve stems were bent..first did you find out what bent them they just bend...and is the valve face seat damaged..if they were not...your engine is out of time or you did not set the valve stem lash when replacing them this allows the intake valves to be open slightly under the firing stroke firing back through the carb and intake...you should have around four thousands of an inch clearance when the springs are completely relaxed and and you should be able to wiggle the valve rocker tappits ...check that if they are correct your engine is out of time..good luck
Oct 10, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My B&S 18hp Intec engine on my lawn tractor will not start but it will backfire??? Will not run
You may get lucky and have a sheared keyway on the flywheel . Just a lil off can make a big difference on timing.
Jul 28, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 22hp intek v twin briggs motor while cutting it just stop now its making a popping noise when trying to start and it wont start just spinning and popping
if its popping out the intake or exhaust,then possibly you have sheared a flywheel key and its out of time,you need to remove the flywheel cover and look to see if this is what happened
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
131 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
