Question about Apple MacBook Pro Notebook
How do you turn off the lit mac logo?
I'd like to turn off the lighted mac logo on the back off the lid
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 131 Answers
If you are talking about the apple symbol, I can't be turned off. if you want that off, you need to turn your screen backlight off then illuminate your screen with another light source which is a bad idea.
it just lets light from the backlight out to illuminate it. it is built that way.
Posted on May 11, 2010
Testimonial: "tym! i hate mac!"
  • Apple Expert
  • 481 Answers
If your reason for turning it off is that it disturbs you when you are trying to sleep (a valid reason for which Apple actually made a hardware modification to the iMac G5!), you can either
1) Put your computer to sleep
2) Turn your screen intensity all the way down at night
3) Apply several thicknesses of Post-It.
Posted on May 16, 2010
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
When i turn the set on i get back lighting but no image or sound.
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 07, 2015 | Vizio M421vt 42-inch 120 Hz Class Edge Lit...
The camera on my photobooth application on my macbook pro is purple and will only take pictures in purple. Anyone know how to get it back to normal?
A ribbon cable connection to the camera may have come loose. First, test it in a brightly lit room to see if the purple is the result of low light, and if that doesn't solve it, LIGHTLY tap the lid behind the camera to see if that reseats the connection. If that does not solve it, follow Apple's troubleshooting guidelines for iSight cameras.
Aug 25, 2013 | Apple Computers & Internet
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
My husbands G4 notebook won't boot up, he doesn't have the start up disc. When he turns it on he gets the apple logo and then the screen turns kinda white like it's lit but not bright. Anyway everything I...
The Command key is commonly known as the apple key or it has a four bladed propellor on it or an apple logo (it may also have cmd on it) the option key generally is the one that says "alt" on it
I would say that if this does not work I would suggest going along to your local apple store who will be only willing to help you and give you advice.
Hope this helps
Nov 25, 2009 | Apple PowerBook G4 17" 1.33GHz Mac...
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Apple MacBook Pro Notebook Logo
306 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
