Question about Canon PowerShot A75 Digital Camera
My Powershot A75 is not being recognized by my windows box nor my macintosh. I have tried different devices with the same cable and USB port to make sure it was not either of those. The camera showed up briefly on the Mac the last time it worked and then disappeared.
    Brigadier General:
  • 11,967 Answers
Do what the pros do...use a card reader.
Posted on May 11, 2010
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
USB device not recognized
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue: http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
Problem with USB cable
Have you tried connecting it to another USB port?
Sep 19, 2008 | Dell PowerEdge 2600 Server
02 possibilities
  1. there might be a problem with your computer check in the system properties, device manager, usb. if all the usb drivers are properly installed the attach the camera.
  2. After connecting the camera switch it on from the top of the camera.
Regards,
Manoj Joseph
+91 9352008418
Jun 14, 2008 | Canon PowerShot A75 Digital Camera
Will not recognize Midair 25 (drivers installed)
Sounds like a USB issue. Is the device self powered? Did you try plugging in a different USB cable? Is it plugged into a powered hub?
USB 1.1 devices and USB 2 devices can cause issues together on the same bus or port. Try keeping devices separate or plug in just the maudio device. I had issues with USB Network adapters not being seen all the way because there was a older usb 1.1 device on the same hub.
Feb 15, 2008 | M-Audio Audiophile USB Audio and MIDI...
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Mio p550 USB devise not recognized.
Try a other usb cable had same problem new cable fixed it of other device
Nov 09, 2007 | Mitac Mio P550 GPS Receiver
Canon PowerShot A75 Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
