Question about 2wire (1000-400108-001) Router
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
    Genius:
  • 1,354 Answers
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Posted on May 11, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
Can I run 2 laptops off the same modem
There are several ways. Windows XP & Vista & 7 have 'ICS' ("Internet Connection Sharing") that allows you to connect the second computer to the first computer, and the first computer to the modem, so that the first computer is a "gateway" to the Internet for the second computer.
Or, buy a "router" -- connect the modem to the "uplink" port on the router,
and connect (wired or wirelessly) multiple computers to the "LAN" ports on the router.
The router acts as a "gateway" to the Internet for all the computers on the LAN.
May 25, 2011 | Computers & Internet
My wife yanked the phone line from the wall and thats when my 2 wire DSL gateway model 2701HG-B modem quit working i plugged into other parts of the house But i just keeps blinking red like its still...
Hello.
Try to unplug power on back of your modem. Let the phone line plugged in. Wait 10 seconds and plug the power back.
Wait about 1 minute and try it with your computer. This procedure will reconnect using a new IP address on your internet service provider.
It should work if you don't have a router. If you have a router attached to your modem, unplug power on both then plug your modem first and wait 1 min. Then plug back your router and wait 1 min. Try your internet connection after doing it. If you still don't have connection, try to restart your computer.
Hope this helps!
Feb 15, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
How do i connect a sbg900 surfboard to a hp deskjet 3050 j610
vague question but I'll try to answer.. the surfboard is a cable modem, so you need a network cable that would plug into your network jack on your PC. if you want more than 1 PC to work, you then need to put a router, wired/wireless between your computer and the modem. A network switch will not allow this to work without first having the router in place.from there you can install multiple switch and computers.
If you mean connect as in configure.. generally, hook up the network cable and use your internet browser to goto http://192.168.1.1 (or what ever your computers Default gateway is) this is typically your gateway address for the router, but the modem will have a similar address usually.
Jan 27, 2011 | Motorola Computers & Internet
I want to know if i can use my netgear wndr 3300 wireless router in conjunction with the telstra 2 wire gateway
Yes, you can definately configure your WNDR3300 to work with Telestra gateway modem. Perform the below steps to reconfigure your WNDR3300 with your Telestra gateway:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Hope this allows you to resolve the issue.
Regards
Anand
Mar 19, 2010 | NetGear Computers & Internet
My router won't work with my Qwest modem.
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | D-Link Computers & Internet
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Need to connect another tower to the 2 wire modem to work fr home
To connect more than one computer to this 2wire you will need to buy an access point (or a router, either one will do). Since the 2-wire is a modem and a router, it can support more than one computer. However, the 2-wire only has one Ethernet slot to support one computer. This is why we need an access point or a router as this will give you more Ethernet slots allowing you to connect more computers to the same Internet connection.
Jan 19, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Setting up the wriless network
You need to have a cable going from the modem to the gateway, and then another wire going from the gateway to the computer.
Oct 04, 2007 | 2wire HomePortal 1800HG Router...
2wire (1000-400108-001) Router Logo
95 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
