Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Black Print Problem
I have a Brother DCP-165C.The BLACK printout has suddenly become foggy. I have gone through the cleaning procedure several times without any success. Colours are okay.
Graham.
  • 493 Answers
Please check the black ink volume. If the black ink is not empty do the followings again:
If you tried the cleaning procedures by print menu,try it 3 times more, for only black cartridge selecting from the menu.
Then you can try checking the print aligment procedures. (Click here to download the manual.)
Print test page.
If the black ink level is very low then you should replace the black ink cartridges to solve your problem :)
Hope this helps.
Posted on May 20, 2010
  • g_robo May 20, 2010
    Dear ioktay,
    Going through the cleaning procedure 3 times has certainly helped, still not perfect, but better.
    Thanks for the tip.
    Graham
  • Ibrahim OKTAY
    Ibrahim OKTAY May 20, 2010
    You're welcome.
    Sometimes holding the cartridge over a water vapor (steam) for a short time and wipe it off with a soft, dry, lint-free cloth helps to clean the dried ink on the print head. But you must be very careful not to damage the print head.
    I did it with my Epson printer once and solved my print problem but I am not sure if it is applicable for your printer or not. This is for your info.
    You may try replacing with another black cartridge. If it prints well then you may think that your current black cartridge makes problem. Then you may try the solution which I did.
    Best wishes.
There are no black ink on my print out. I have replaced with a new one and have cleaned it for several times and still no black printout..My machine is more than 1 year old.
This is a common problem that Brother will pay to repair. You need to call 1-877-brother and tell them the problem. They should then get you set up to have the print head replaced.
Aug 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Sep 15, 2010 | Brother DCP 165C Compact Color Inkjet...
What are the procedure to use only black ink using brother DCP-165c?
Description of Problem 100000016244
Can I print using only the black ink cartridge when any of the color cartridges are empty? Grayscale
Description of Solution 200000023550
To view information and instructions with graphics please go to the website listed below:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000061/faq002461_001.html?reg=us&c=us&lang=en&prod=mfc6490cw_all
Jul 10, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Mar 01, 2010 | Brother DCP 165C Compact Color Inkjet...
New Brother won't print black
Take the printer back to where you got it from and exchane it for another one...
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
I can't print in black
You'll need to see the manual on how to do a head clean.
Jun 07, 2009 | Brother DCP 165C Compact Color Inkjet...
My brother dcp 165c wont print in black
Hello, please make sure that your cartdridg is well installed and that you took off all protections on it. Unplug your printer from the ac dc and replug it...
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
